PCV valve assembly part I.D.
Old May 5, 2026 | 10:44 PM
kameronth's Avatar
kameronth
Pulled my 5.8 on my 96 to reseal the engine. Truck sat for years so just about every gasket and seal is hardened and leaking. I’ve got a new PCV valve and grommet that goes into the valve cover but does anyone know the part number or where to find the plastic cap? From what little info I can find, it’s unique to the 96 models.
Old May 6, 2026 | 02:45 AM
AuroraGirl's Avatar
AuroraGirl
what’s wrong with yours? It’s a baffled air vent like the crankcase takes fresh post-maf(if applicable) air into the engine and it has baffles to lower the air velocity/not splash oil into the air stream I think
Old May 6, 2026 | 06:29 AM
R&RFord's Avatar
R&RFord
Is it not the same part as the 4.9 breather?
Old May 6, 2026 | 07:35 AM
kenny nunez's Avatar
kenny nunez
PCV
Be sure to replace the valve with a genuine Ford valve.
Old May 6, 2026 | 07:48 AM
Hit Man X's Avatar
Hit Man X
What it looks like to me.
Old May 6, 2026 | 08:15 AM
kameronth's Avatar
kameronth
Nothing, but since I have the plenum off, it would be nice to replace. That makes sense, thanks for the info!
Old May 6, 2026 | 08:16 AM
kameronth's Avatar
kameronth
I'll take a look at that. It does appear to be the same.
Old May 6, 2026 | 09:22 AM
R&RFord's Avatar
R&RFord
Pretty sure it is full of aluminum mesh to catch oil vapor. If the case is good you can run some solvent through it let it dry and reinstall.
Old May 6, 2026 | 09:27 AM
Hit Man X's Avatar
Hit Man X
Does it have a PN? If so, post as I am by my 4.9 to compare for ya
Old May 6, 2026 | 09:35 AM
kameronth's Avatar
kameronth
I'm not going to be home for a bit to take a look, but I appreciate the offer!
Old May 6, 2026 | 04:18 PM
R&RFord's Avatar
R&RFord
4.9 part. Port going into the grommet is 3/4". Hose barb is 1/2".
The L hose is 3/4 on both ends on my 94 5.8. Is your hose different?
Seems like it would be great at stopping oil vapors getting sucked up, once you work out the hose issue.
Old May 6, 2026 | 10:39 PM
kameronth's Avatar
kameronth
I appreciate the part info. I’ll look at picking that up. The elbow on mine is large at the end that the PCV valve sits in than the side that goes into the breather. No luck finding locally. The 96 is an oddball year.
Old May 7, 2026 | 09:12 AM
Hit Man X's Avatar
Hit Man X
What about swapping a '95 and earlier cover on that bank to make life easier?
Old May 7, 2026 | 09:50 AM
kameronth's Avatar
kameronth
That's a good idea and I may have to do it in the future with these hard to find 96 specific items. I want to slap the engine back in the truck this weekend so I don't have the patience to wait on parts.
Old May 7, 2026 | 11:23 AM
R&RFord's Avatar
R&RFord
I don't think there is any difference in the valve cover.
