NOS block. You can see the 3 cross bolts down low and the three brass screw in water jacket core plugs rather than press fit steel cups.
Also drilled for hydraulic lifters.
Here's the engine tag. Not the typical format with year and month of production but seems to indicate a 427 HP. The engine date code is very hard to read. The second character is an L - November and then maybe a 25? But the first character I'm not sure. Possibly an 8 but you can see it's a bit of a blob.
It came with 8 rods with C6AE-E ID on each. They have been worked on some on the sides but have 8-point cap screws and have never been installed in an engine as far as I can tell.
