Just wanted to share that this weekend I decided to try out the ride difference with the front sway bar removed after reading all the positive comments in this forum. Result: WOW! It almost feels like a totally different vehicle. Wayyy less side-to-side rocking. I also tested if it would feel dangerous under emergency maneuvers and could not tell any different in roll or lean when doing extreme cornering fully loaded. So, thanks all! What a major day to day improvement!
Now I’m wondering what the ride difference would be comparing the sway bar to the anti-sway bar.
it's not too hard to unhook one side, zip tie it up, and go for a drive to see...exactly what i did, when i got back i went under and took the ~32 lbs of coffee shaker off completely, i roll basically half ton loads, zero roll, zero concerns
I've been doing this "mod" to all my trucks that had one for years. Off road flex has incredibly improved keeping both front wheels on the ground providing better traction. Try the truck in a culvert and watch it flex, the coil suspension really shines vs leaf springs I had on mt '97 F-350
Really? Removing the anti sway bar gave you LESS rocking, and you didn't feel more roll or lean in emergency maneuvers or extreme cornering? Seems to defy logic. I wonder what the explanation is?
I think the rolling hes talking about, is the jarring left to right you get crossing a curb at 45 degrees, into a driveway or gas station. Thats totally the sway bars fault. Rams soft sway bars make this more obvious.
My truck has plow springs and loads no heavier than what a piddly toyota could handle. So roll is minor with the sway bar gone.
I've done the same. My 2018 was the only truck I didn't do it to.
I guess I know what I'm doing this weekend on my 2024....
Alright ya'll convinced me to just take the sway bar off. Yeah it makes a pretty big difference in comfort, and yeah the additional body roll when driving is almost imperceptible. I was keeping an eye out for a Tremor bar and I'll probably still look every now and then but I don't see the need now. I expected a fairly significant change in body roll at highway speeds around curves but it's fine. What's really nice is the body rock I used to get from hitting a bump or pothole on just one side doesn't happen any longer.
What about overextending the suspension in the front? Any fears of over-articulation (if that's a thing) and the shocks reaching their extended limit? Is there any risk here when the anti-sway bar is removed?
None. The sway isn't what's limiting extension, and it only reduces articulation when the movement isn't even side-to-side. It's not in the equation when approaching square to a bump like speed bumps, or full droop like having the truck on a lift.
