I mentioned in a post here last week about my truck suddenly failing to charge. I was advised to check the "Exciter" wire. So, after reading several threads on the subject, I performed a few tests.
My truck has no voltage at the R/G wire. No voltage at B/W wire. 12v at Y/W wire.
I have the original cluster in the truck but it has been in and out a few times lately. It has a voltmeter gauge. Wien the key is turned to the on/run position the battery indicator lamp does not illuminate.
Recently, the left turn indicator lamp failed and was corrected by simply cleaning the lamp socket and circuit board. Could my alternator repair be as simple as fixing that battery indicator lamp?
Red/green is what sends 12V to the voltage reg. Start there. Yes, no batt lamp causes issues. No idea if 95MY have a resistor to still charge regardless of the bulb. No real reason to diag further until you have 12V there.
Buy an EVTM for these, best money you can spend to see what goes where and how
Simple repair I am sure.
Hell, need to see if there is a quick disconnect for that wire near the batt. If so, a simple wire with alligator clips on both ends can jump it and shoot power to the alt. If it charges, use a DVOM, then back track to the cluster.
Thanks for the help. I jumped battery voltage to the R/G wire at the alternator and it started charging fine. I'll fix the charging system indicator lamp next.
Notice I changed "battery" indicator lamp to "charging system" indicator lamp. That's what the Owners Manual calls it.
Got back to this job today. I pulled the cluster out so I could work at the bench. The charging system indicator lamp showed no continuity. I cleaned up the bulb socket a bit, pulled the bulb (good) out and then plugged back in several times and re-established continuity.
With the bulb out of the cluster, the 513 ohm resistor tests dead (open ). So, I guess no power through the bulb or resistor was/is the problem. Also, the larger red with green wire opposite the green with red wire on the cluster connector is powered with key on. This wire is the ignition feed if Haynes is to be believed.
Note to self (others):
I mentioned I've had this cluster out several times. The two larger connectors always put up a bit of a fight. Today, releasing the connector on the tach side of the cluster, I pulled two copper foils loose from the plastic. Investigating, I noticed both of these type connections are sticky. Sticky as in adhering. Though they looked clean, the cleaning cloth with electric cleaner came out brown. Got the sticky cleaned off and re-affixed the two copper foils back in place with super glue. Polished all with 600 grit paper.
I trimmed a very thin silver off the openings where the lock tabs catch. The connectors are easy in and out now.
