Help finding/naming the right part!
Old Apr 22, 2026 | 05:49 PM
offwhitefueler's Avatar
offwhitefueler
Had a new water pump installed and after the job (too far to tow back) lost power and realized the alternator mounting bracket is cracked. I'm having trouble finding the right part. I'd rather go oem if possible as all the new ones look completely different, super smooth and shiny with none of the extra ridges or even the same shape. Does anyone have any input on this?
Thanks for any help!
Christa
Old Apr 22, 2026 | 06:03 PM
90project5.0's Avatar
90project5.0
Local junkyards,eBay or car-part.com Someone got a little overly strong on the bolts?
Old Apr 22, 2026 | 06:17 PM
offwhitefueler
Found a few on ebay but they all look a little different, or maybe I'm blind... I haven't looked at car-part.com, never heard of it. Thank you!
Yeah, the mechanic said "lots of old things were breaking" like clamps and bolts and whatnot. He said he replaced things so the job took longer than he expected. When I told them about the bracket they said to bring it back and they'd cover the cost of the replacement and work. It cost me more to tow it there than the labor!
Old Apr 22, 2026 | 06:24 PM
90project5.0
They should have covered the tow or send a mechanic there to fix it!
skipped the title part, it’s called an accessory bracket… my bad!
Old Apr 22, 2026 | 07:35 PM
offwhitefueler
Shoot! Thank you! Does this look right? Is it the same for a diesel or is there some weird thing that's different? https://www.ebay.com/itm/18814432987...4yh8urK-0zEO3A
Old Apr 22, 2026 | 08:45 PM
90project5.0
I don’t believe they are the same. That looks a little short, but I have never seen a deisel to say. Hopefully someone else will chime in!
Old Apr 22, 2026 | 08:48 PM
90project5.0
https://www.ebay.com/itm/33554458827...yABEgI0z_D_BwE
Price is dumb, but if you can’t find it anywhere else..
Old Apr 22, 2026 | 09:46 PM
offwhitefueler
That price is dumb! Any downside to ordering used? Assuming someone doesn't overtighten a bolt! This looks right... https://ebay.us/m/QX3x2n
Old Apr 22, 2026 | 09:47 PM
offwhitefueler
And thank you for the help! Just want what's best for the truck.
Old Apr 23, 2026 | 05:55 AM
90project5.0
Im not against used at all! To me that price is still high, but a lot better! If you cared what it looks like under the hood, you could always clean it before install. I just did a quick glance when I found the other one!
Old Apr 23, 2026 | 07:59 AM
wwhite's Avatar
wwhite
I think some clarification is needed with this part.
From the original picture, looks like it is on the drivers side of the vehicle.
That would indicate it is the Power Steering and AC bracket not the Alternator/Smog bracket.
Correct, it is the Power Steering pump and AC bracket on the driver side?
Old Apr 23, 2026 | 08:17 AM
offwhitefueler
It is on the driver's side. I'll check and confirm, thank you. This is why I'm here. Best if I don’t self diagnose.
Old Apr 23, 2026 | 01:41 PM
offwhitefueler
Thinking on it, I don't see how the truck would lose power/acceleration from a power steering pump bracket issue. I drove it home super slow, battery light came on and acceleration was choppy under second gear. Maybe I have more than one issue.
Old Apr 23, 2026 | 05:00 PM
wwhite's Avatar
wwhite
Broken bracket would cause that. Sounds like either your alternator is going bad or bad electrical connections.
Old Apr 23, 2026 | 06:50 PM
offwhitefueler
Dug a little more- accessory bracket is the right term I think. It is for alternator, power steering and smog? Does that sound right?
Sailor Roy
Montana Chapter
188
Mar 1, 2025 09:33 AM
DSLTRK60
Oct 1, 2023 12:49 PM
Csnell3732
Large Truck
Jan 19, 2022 09:32 PM
RL250
138
Nov 17, 2014 04:07 PM
MP&C
Aug 30, 2009 11:01 AM
