Calibrate speedometer
Old Apr 18, 2026 | 01:11 AM
Cliffblue's Avatar
Cliffblue
2020 XLT. Installed slightly taller tires. Speedometer is 2 mph off at 60 mph per gps. It was right on with previous tires. 2 different dealers say they can’t correct it and the last one suggested an after market programmer to true it up. Does this sound right?
Old Apr 18, 2026 | 07:29 AM
SMSTX's Avatar
SMSTX
Yes, newer versions of IDS and FDRS do not support changing tire sizes. You need forscan or another programmer to recalibrate
Old Apr 18, 2026 | 07:53 AM
Barkyy's Avatar
Barkyy
Totally correct
Old Apr 18, 2026 | 09:15 AM
SpencerPJ's Avatar
SpencerPJ
Very easy correction with Forscan. All you need is a laptop, dongle ($50) and free Forscan program. Other great advantages of having Forscan. The Dealer saying can not be done, is the go away attitude.
Old Apr 18, 2026 | 09:38 AM
Don Ridley's Avatar
Don Ridley
YouTube is a good start if you want to use Forscan, but you should read a little on what you need to do to stay out of trouble. Some forum users created a great resource:
https://www.ford-trucks.com/forums/1...ces-index.html
Buy the Forscan recommend adapter (OBD Link or Vlinker) because you are making changes, not just reading data. You don't need any irreversible problems a bad adapter can cause.
Old Apr 18, 2026 | 03:08 PM
SMSTX's Avatar
SMSTX
The dealer saying cannot be done is because of Ford software. If the dealer makes changes using outside software, the dealer has a liability that is not backed by Ford. If Ford software screws up, the dealer has a recourse through Ford, be it technical assistance, software development, etc.
Old Apr 18, 2026 | 04:15 PM
JKBrad's Avatar
JKBrad
You can use FORscan, as stated above. When I did my truck, 10 years ago, I used a Hypertech calibrator. My tires are spec's at 34.4", but that's unloaded. The reason I didn't use FORscan at the time was that I had a Mac laptop.
To get my speedometer to read correctly, I had to enter 33.25" into the calibrator to get it perfect. For what it's worth, nearly every F150 comes from the factory with the speedometer read about 3% fast. Check with a speedometer app that you can download on your phone, there are many in the app store.
Old Apr 18, 2026 | 08:45 PM
Cliffblue's Avatar
Cliffblue
Well, my 2 laptops are Windows 7 and 10. Neither are suitable for 11. I pretty much do everything on my phone now. Messing around in that program is not something I am comfortable with. That’s the reason I went to 2 dealers to have an experienced person do it. I still have some extended warranty left and I wouldn’t want to give them an excuse to decline a repair. I may have to just live with it. Thanks for taking the time to reply all.
Old Apr 18, 2026 | 09:03 PM
JKBrad's Avatar
JKBrad
Here's what I used. It was fairly easy to do. This is the best price I found.
https://dalessuperstore.com/i-238994...hoCat0QAvD_BwE
Old Apr 19, 2026 | 10:34 AM
GlueGuy's Avatar
GlueGuy
Sounds about right. When my speedometer says I'm doing 35, the radar trailers show me doing 34. So I usually add at least 1 MPH to do the speed limit. Double that at freeway speeds.
JimmyWayne23
16
Jul 30, 2022 12:57 PM
metru
Nov 8, 2017 09:26 PM
Ltngdrvr
6.7L Power Stroke Diesel
34
Apr 25, 2014 12:03 AM
6brau
May 24, 2013 12:48 PM
nitropolaris2
1997 - 2003 F150
Nov 2, 2004 11:40 PM
