Sponsored by: Auxito
Rust in Windshield Channel
Old Apr 15, 2026 | 03:12 AM
Aaronw12's Avatar
Aaronw12
2004 F-150 Heritage, I had the windshield removed and resealed by a glass shop about 5-6 years ago due to it leaking and dripping from the passenger side grab handle during rains. When they had the windshield out there was rust on the passenger side top of the window channel. Believed to have been the cause of the leak. They "treated" the rust by wire wheeling and painting it before reinstalling the windshield. The leak has returned, when looking under the top molding I can see the paint they applied is loosing it's bond. I'm thinking about taking a shot at fixing this. What would my best bet be at removing the windshield? The glass is in good shape, no cracks or filled chips that I know of. Won't know the extend of the damage until the window is removed but when looking up from inside the channel appears to be solid. What's the typical method of permanently fixing something like this?
Old May 3, 2026 | 02:12 PM
YaraDonovan221's Avatar
YaraDonovan221
1st Gear
Es klingt, als ob die Rostbehandlung und das erneute Versiegeln nicht dauerhaft genug waren. Um das Problem richtig zu beheben, solltest du zunächst die Windschutzscheibe vorsichtig entfernen. Normalerweise wird hierfür ein spezieller Glasentferner verwendet, um die Scheibe ohne Beschädigung zu lösen. Wenn du die Scheibe entfernt hast, solltest du die Roststellen gründlich reinigen, eventuell erneut abschleifen casino mit paysafecard und dann mit einer Rostschutzgrundierung behandeln. Danach sollte der Bereich mit einem geeigneten Versiegelungsmaterial neu abgedichtet werden. Es ist wichtig, sicherzustellen, dass der Rost nicht tiefer geht, bevor du mit der Versiegelung fortfährst.
Old May 3, 2026 | 02:33 PM
RacingJake's Avatar
RacingJake
In English. It sounds as if the rust treatment and resealing were not permanent enough. To fix the problem properly, you should first carefully remove the windshield. Usually, a special glass remover is used for this purpose to loosen the pane without damage. Once you've removed the window, you should clean the rust spots thoroughly, sand them down again if necessary, and then treat them with an anti-rust primer. The area should then be resealed with a suitable sealing material. It's important to make sure that the rust doesn't go deeper before proceeding with the sealant.
Aaronw12
1997 - 2003 F150
Feb 4, 2025 05:39 AM
15W-40
Dec 2, 2020 02:24 PM
Clem's Cousin
Oct 25, 2014 06:46 AM
Shwan_89HD
Jan 4, 2013 09:07 PM
Ford XLT 4x4
Sep 21, 2011 11:13 PM
