Cat oil Filter
Old Apr 11, 2026 | 01:15 PM
southpaw333's Avatar
southpaw333
3rd Gear
Cat oil Filter
What are the comments on doing the CAT oil filter conversion on the 6.7l power stroke. My year is 2022 f 250
Old Apr 11, 2026 | 01:30 PM
Midwest87's Avatar
Midwest87
What conversion? Theres a direct spin on. Cat has 10,087 types of filters. Im sure one fits.
https://blackmarketperformance.com/products/11-6-7-powerstroke-cat-oil-filter-direct-replacement?srsltid=AfmBOooaR5jQJMQ4tGdEgQj_-QkMvmtAU3z6ENfZtmvLwqyaT2JVhtkJ
But if Cat guys dont bother with this..............
Most Cat engines have a rather nice bypass piston on the engine. Your ford 6.7 uses one in the filter, last I checked
. Stick with the Ford filter.
Old Apr 11, 2026 | 01:55 PM
speakerfritz's Avatar
speakerfritz
I put the cat conversion kit on that has the replacement oil filter head from spe.
pros are I picked up extra npt ports.
cons is the cat filter has no by pass valve
dont have any way of monitoring psi and thru put so anything else would just be theoretical.
Old Apr 11, 2026 | 03:17 PM
Dustin F450's Avatar
Dustin F450
With no bypass in the filter, it's a solution looking for a problem. That's a lame upgrade aka brodozer bling.
get a Donaldson P502503 and be done with it.
Old Apr 11, 2026 | 05:08 PM
cpobst's Avatar
cpobst
I recently found out that you can monitor oil pressure on 2020+ trucks with an iDash pro. I got one recently and the pressure is post filter.
Old Apr 13, 2026 | 09:34 AM
rufushusky's Avatar
rufushusky
There are a couple options if you want a cat oil filter on your truck:
SPE:
https://blessedperformance.com/spe-m...l-powerstroke/
Chinesium temu SPE
https://www.spelabautoparts.com/prod...saAhr6EALw_wcB
Or a spin on adapter
https://www.mddperformance.com/67-po...MaAsWwEALw_wcB
IMHO, the juice isn't really worth the squeeze. Your picking up capacity and that is about it, the OEM filter is a tighter media and contains the bypass valve that Cat assumes you have in the head. Motorcraft, Wix, Donaldson, Baldwin, Fleetguard all make a great option for our trucks.
Old Apr 13, 2026 | 01:16 PM
speakerfritz
could be a problem under a combo senerio.....full filter...thick oil...cold weather...compounded by the efficiency of the filter...they claim 5 microns at 20%......20 degree 10W30 wont flow very well thru a 5 micron filter.
I have the SPE setup mainly for the extra ports and used the longer filter option......when I replace the filter im going to find a micron option that is not as tight.....dont need 5 micron on the main filter since I have 2 micron on bypass filters. I would rather have better cold weather flow.
cpobst
Jun 8, 2026 09:16 PM
jimzpsd
6.7L Power Stroke Diesel
26
May 20, 2025 01:07 PM
4x4countryboy
17
Mar 29, 2023 07:29 AM
Ford4Life7.3
Feb 23, 2014 11:05 PM
ernesteugene
120
Dec 22, 2008 04:04 PM
