Sponsored by: Real Truck
6.0 PSD
Old Apr 7, 2026 | 11:45 AM
LUMBERMAN's Avatar
LUMBERMAN
6.0 PSD
I have a 2006 F350 srw that I’m considering getting “BulletProofed “ .Im just looking for suggestions, am I making a mistake? Thanks Lou
Old Apr 8, 2026 | 06:08 AM
99powerstrokedF250's Avatar
99powerstrokedF250
If it's a 6.0 that is still running good, you got a good one...it can't hurt to throw the head studs and such at it, but it would be up to you if you did a tune. Do NOT do a tune without supporting mods.
Old Apr 8, 2026 | 07:24 AM
Baylinerchuck's Avatar
Baylinerchuck
If there are currently no issues with the truck I would suggest leaving it alone. Good maintenance goes a long way. If you haven’t done a coolant flush and replace with ELC you need to. If you don’t have a way of monitoring deltas and other key PIDs you need one. You also need to monitor fuel pressure. If I’m keeping the truck, I wouldn’t do the studs unless I had the heads checked out or replaced, and the block deck surface dressed up.
Head over to the 6.0 section of the forum for lots of good information on this platform.
Old Apr 8, 2026 | 06:40 PM
LUMBERMAN's Avatar
LUMBERMAN
Thanks for responses , the head gaskets are good and I’m having other issues taken care of but no Bullet proofing
FishOnOne
May 11, 2023 09:29 AM
ssunit1
Aug 26, 2021 09:49 PM
senix
General Diesel Discussion
Aug 22, 2010 07:03 PM
