94 explorer starting issue
Old Dec 10, 2003 | 12:20 PM
roborob76's Avatar
roborob76
My explorer only clicks when turning the key- sometimes.
Could this possibly be just a bad connection ?
Starter is new, battery is good....
any idears ?
Old Dec 10, 2003 | 01:08 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Might be, but if you post this in the Explorer forum I bet you'll get more answers/ideas.
Old Dec 11, 2003 | 02:07 AM
Jet Lizard's Avatar
Jet Lizard
Try to check negative battery cable connection. It could be possible reason. Never seen such an issue on my Ex, so I cannot be more specific. I believe the problem is with the cable connection to the truck's body or engine or something -- where the cable is connected to the ground.
Also check battery cable terminals, they could be corroded.
With best regards,
Yuri
Old Dec 11, 2003 | 05:19 AM
marragtop's Avatar
marragtop
The 'click' that you refer to, is it coming from the starter or the solenoid on the fenderwell/firewall? Could be a bad cable, solenoid, or starter. Start by checking all cable connections.
