Fluid leaking from Speedo cable
Old Mar 29, 2026 | 06:01 PM
90project5.0's Avatar
90project5.0
No. The tiny pieces of plastic are probably already ground up. If the gear looks like that after 6 months, is it the wrong gear for the drive gear?
I don’t think so. Same supplier that gave me the 20 tooth gear when I swapped 3.55s gave me the 23 tooth for 4.10s. I have the 6 tooth drive gear. Both descriptions stated for manual transmission.
Old Mar 29, 2026 | 06:04 PM
90project5.0
It popped right on mine
Yeah, not for me, 45 minutes later with enough cuss words for the wife to come out and say to stop cussing so much (first time that’s happened actually) and I never got it, so I made it work my way. Did you put the cable in first and then push the clip through or did you have the clip in place and it pushed through it?
Old Mar 29, 2026 | 08:28 PM
manicmechanic007's Avatar
manicmechanic007
Clip in there, and then push cable in
The square needs to be lined up
Old Mar 29, 2026 | 09:00 PM
90project5.0
My test drive indicates that it most likely isn’t in all the way haha. Speedo not working at all. I’ll pull it off in the morning and reseat it. Thank you!
Old Mar 29, 2026 | 09:07 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Thats my guess. The speedometer cable end isn’t seated in the sensor which is why it won’t go in far enough.
MainetoDC
Oct 1, 2017 01:28 PM
KG Excursion
Aug 24, 2014 02:29 PM
ErrorS
1978 - 1996 Big Bronco
Dec 2, 2011 10:37 AM
oldnnew
Jul 24, 2004 06:31 AM
