Rocker arm torque settings
Old Dec 10, 2003 | 10:21 AM
isaz's Avatar
isaz
I have a ticking noise in a 400 of a 79 f250 4x4 crew cab.It
sounds like the rockers arms to me i want to retourque them before changeing anything to see if that works.What are the torque settings they are stock.
Tahnk you
Old Dec 10, 2003 | 11:58 PM
Superdave's Avatar
Superdave
Its more than likely that it is worn rockers and or pushrods causing your valvetrain tick.
This is a common issue with these motors.
The torque spec is 18 - 25 ft.lbs
Old Dec 11, 2003 | 12:19 AM
Rambomber's Avatar
Rambomber
How many miles on your motor? I have bent two pushrods in mine and I am at 85,000 miles. Cheap fix, but not knowing why this is happening is annoying.
Old Dec 11, 2003 | 10:38 AM
isaz's Avatar
isaz
I just bought this truck.The owner had it for 10 years and did not make any modification to the engine at all.I found some paper work in the glovebox and the previous owner before the man i bought it from had Ford Motor company install a new block.The truck had 86,000 when they installed in now the truack has 26,000 so the heads have 126,000 miles i suppose.
Old Dec 12, 2003 | 08:30 AM
ranchero77's Avatar
ranchero77
Rambo, an engine back fire will cause the bent push rods. I had one bend and fall out out after a couple of backfires in my 400 when I had put the stock 2bbl carb on before I did emisions.
isaz, so the engine only has 40K miles. you can first take the vavle covers off and check between the rocker tip and top of the valve step with a feeler gauge while the engine is at idle. use about a .005" leaf. it could be a bad lifter or pushrod
Old Dec 14, 2003 | 12:02 AM
Superdave's Avatar
Superdave
And the rocker arms get worn between the fulcrum and the inside of the rocker arm. This creates slop and causes them to tick.
Was the install a long block?
gameover1974
Dec 9, 2015 07:25 PM
fordpride
Jan 10, 2010 06:38 PM
Blurry94
3.8 & 4.2L V6
Apr 1, 2004 07:14 AM
74dually
Aug 22, 2002 01:36 AM
mike460
May 14, 2001 02:15 AM
