alt swap
Old Dec 10, 2003 | 10:06 AM
bajascott's Avatar
bajascott
alt swap
i have a 77 f150 ex-cab and i have a problem with with the charging system i think.... do these trucks usually have fairly dim lights?? at night they are pretty dim and when i turn on an accessory like heater or what ever they go dimmer.i replaced the the chassis ground. ant regulator.no change
can i install an internally regulated alt.on it i have one off a later model 302 injected car(i assume it puts out more amps)
what do you think?? what can i do with out spending a fortune on a higher end unit??
Old Dec 10, 2003 | 09:01 PM
Franklin2's Avatar
Franklin2
The stock system was perfectly adequate for the truck's normal usage. I would check the voltage at the battery. Should be around 13-14 volts with the truck running. If that looks ok, check the voltage at the headlamps. It should be around 12 volts.
It might be something as simple as the alternator belt being worn out or a little loose.
Old Dec 11, 2003 | 12:43 AM
bajascott's Avatar
bajascott
well i have some other lights i am running also but not all the time
i will check the belt and voltage thnk you for your time!
Old Dec 11, 2003 | 11:11 AM
William's Avatar
William
Check out the tech article section one called "whiter whites brighter brights" the other 85 amp one wire alternator install. I wrote the one on the alternator and use the relays for lights. I also use sylvania halogen bulbs. I have plenty of light, at idle with the heat on as well.
Old Dec 13, 2003 | 10:45 AM
bajascott's Avatar
bajascott
thanx i'll check it out. it sucks at a stoplight with the low's on radio ,and heater at the same time.cant see! thanx again!
Old Dec 13, 2003 | 08:08 PM
Nod's Avatar
Nod
Poor lights
Don't forget to check the ground wires at the headlights,sometimes they get corroded and takes a lot more amps to push through all that corrosion,or is it volts,well any way just my 2 cents.
"bowties in the rearview mirrror"
