View Poll Results: why wont he start?
the cam shot?
0%
timing chain jump again?
0%
distributor shot?
0%
spark plugs?
0%
Voters: 0. You may not vote on this poll
need help asap please
Old Dec 10, 2003 | 09:00 AM
bonnieslaw's Avatar
bonnieslaw
Unhappy need help asap please
my 302 wont start-turns over but no go. have replaced timing chain, rotor,cap, condenser,points, basically everything electrical, getting gas, but it is being pushed up thru the carb. what is wrong? single mom just trying to get my motorhome running again soon. could it be the cam is shot? how can i tell? thank you for any help.
Old Dec 10, 2003 | 09:12 AM
TheWiz427's Avatar
TheWiz427
You do not need to post a poll about your problem.
Check your timing! if it's blowing gas up thru the carb the timing is off
Old Dec 10, 2003 | 08:56 PM
gonetruckin's Avatar
gonetruckin
i could be a number of things did you make sure the fireing order is right and when you put your timing chain in did you make sure that you where at top dead center and lined up all right? or the gap in your plugs could be wrong//// the quickest way to check to see if you are at top dead center is to find your number 1 cylinder and take the plug out and stick a screwdriver in the hole and manualy turn over your crank until the screwdriver is as high as it will go and then look at your distributer bug and it should be pretty close to the number 1 plug wire or the total oppisite side and if its way off, you have problems..... oh also check your coil and see if its good... but really it could be a number of things
