Electrical getting hot, inertia switch help
I posted in another forum and on Facebook but still need help here. I will post a link below to the other forum for anyone willing to read and catch up
Pretty much, the there's one particular wire going to the inertia switch that is getting hot. I reduced wire length and connections, and used solder connectors from amazon on this, and on my blower motor
I added a relay on my blower motor, ground-switched, in an effort to stop this one particular YELLOW ignition wire from heating up. It worked for a while, but now the relay is so sensitive that a bump will stop my fan from running.
What I've done for blower motor:
•Ground-switched relay
•New motor and thermal thing a few years ago.
Inertia switch:
•Swapped inertia switches with known good one
•Bypassed I. switch with paperclip
•New LP assembly and HP fuel pump + electrical cleaner on connections.
•Swapped ECM and FP relays but still the wires for I. switch get hot. Also, the 12V hot on the HP pump gets hot right at the pigtail
Here's the link and any help would be much appreciated
https://www.ford-trucks.com/forums/1801479-inertia-switch-help-2.html#post21791874
I'll check my blower motor and blower motor relay grounds as well and verify all grounds with my power probe.
Thanks for the help. I'm learning a lot but there's still a lot to learn
