6.0 runs fine, starts shuttering, the dies?
Old Mar 22, 2026 | 04:16 PM
Brad ORourke's Avatar
Brad ORourke
Hey fellas, it’s been a while hope all is well. So Friday afternoon on my way home, my 2006 psd started shuttering and stalled out, like it wasn’t getting fuel, I picked up some motorcraft filters yesterday and just put them in. I just made it about a mile from my house and it did the same thing. Just for grins I had my Forscan plugged in while I was driving so I have the drive cycle saved, but I didn’t really see anything that stood out, any ideas?
Brad
Old Mar 23, 2026 | 12:06 AM
BLADE35's Avatar
BLADE35
Sounds like an injector
aration testing upper fuel bowel??
FICM and voltage ok
Old Mar 23, 2026 | 05:30 AM
Brad ORourke
FICM and voltage ok
it looks like my fuel gauge has decided to not work properly, I looked in the upper filter bowl and it was empty, had my kid bring me a couple cans of fuel and it seems fine. I’m guessing the sending unit might be messed up
Old Mar 23, 2026 | 06:50 AM
Brad ORourke
So basically the tank was empty but the gauge was saying just over 1/4 tank and the readout said 50 miles to empty. I’m not sure if there is a way to fix it, but I guess not running less than a half tank is the remedy for now.
Old Mar 23, 2026 | 08:44 AM
TooManyToys.'s Avatar
TooManyToys.
Old Mar 23, 2026 | 09:19 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yeah man, been there for a couple years now. The Ex has a dead spot in the sending unit, and the 250 most likely has a broken foot that needs replacing. I just don't let them go below half because I haven't wanted to do the work yet.
Your problem might be the broken foot on the pickup. There's still a 1/4 tank left it just doesn't reach down into the fuel anymore. Whatever is it, the tank has to get opened up, unless you want to cut a hole for a sump system. Pics of this problem in this post link:
https://www.ford-trucks.com/forums/1...l#post21786669
I got a Fleece to put in my truck, but there are full replacements of the standard style also available. I chose to replace the whole thing, my logic is the first one made it twenty years, the replacement probably will too and I don't want to open up the tank again if I can avoid it.
https://www.xtremediesel.com/fleece-...sf-fmc-9907-sb
https://www.xtremediesel.com/delphi-...k-sending-unit
Old Mar 24, 2026 | 07:14 AM
Brad ORourke
Right on fellas, I’ll probably just hold off for now, still a little cold and too much snow to mess with it now.
snook06
Feb 26, 2025 07:46 PM
QuadSe7en
Aug 24, 2021 04:13 PM
Mcrafty1
Jul 30, 2013 06:32 PM
G4ORCEBOYS
Mar 12, 2012 11:19 AM
