1978 - 1996 Big Bronco
brake problem RABS??
Old Dec 10, 2003 | 08:21 AM
Thibor91XLT's Avatar
Thibor91XLT
Question brake problem RABS??
I've noticed the last week or so intermittent increase in brake pedal travel. From highway speeds it's fine but when I stop and need to wait for a minute the pedal drops quite a bit. Stop and go at slow speeds really brings it out. Pedal pumps up fine and holds pressure when engine is off and doesn't start the "drop" until I start driving around. It sure sounds like the "rear anti-lock brake " thing referenced in another "brake" search.
Is the fix to this problem more or less expensive than a master cylinder? As I said, the brakes don't show any other problem and stop fine from higher speeds until I get to going really slow.
Thanks !!
