broken rocker arm
Old Mar 14, 2026 | 11:55 AM
4wheelexcursion's Avatar
4wheelexcursion
broken rocker arm
I just had new O ringed heads put on my 03 with the 6.0. After 5K miles it was back to the shop with a broken rocker arm! My mechanic did not replace any of the rocker arms or pushrods when installing the new heads, is this my problem or was this just a one off? has anyone who replaced their OEM heads with O ringed heads let me know what you have done? Is 6.4 pushrods the way to go to solve this issue?
thanks in advance
Old Mar 14, 2026 | 05:00 PM
John in OkieLand's Avatar
John in OkieLand
have not pulled heads off anything with more than 2 cylinders , since 1954....
but, that sounds like you are going to need to bore scope the cylinder to make sure no damage was done to the piston or valves.
I have watched Dave's Auto repair many engines with broken rockers, and even some crankshafts.
Old Mar 14, 2026 | 05:48 PM
Antonm23's Avatar
Antonm23
The only way to get rid of 6.0 problems,,, is to get rid of the 6.0. There is no fix, or combination of fixes, that can make the 6.0 not do 6.0 things.
Old Mar 14, 2026 | 08:03 PM
John in OkieLand
Originally Posted by Antonm23
The only way to get rid of 6.0 problem,,, is to get rid of the 6.0. There is no fix, or combination of fixes, that can make the 6.0 not do 6.0 things.
I was being a bit more gentle than that,
but,
when I was on the market search, the only thing I looked at, was 4x4 and 7.3 diesels.
Thinlizzy13
Oct 11, 2015 03:47 PM
cwpowell
Mar 2, 2006 07:12 PM
ohioredneck
Bronco II
Nov 14, 2004 10:37 PM
WALJON
Dec 24, 2003 03:25 PM
