I have a 1963 f700 and was wondering if anyone has a part number for the hydrovac brake booster, this is a frame mounted and has an air intake that goes into the cab. Also looking for the brake hoses to the front wheels and rear axle. Duel rear wheels. Only item i found was the master cylinder. thank you in advance.
It depends if your booster is 11.00" or 12.75" in diameter. If it is the 12.75" then it has been discussed a few times before. One example thread below. Ford and Bendix part numbers.
