5.4 flex fuel
Old Mar 9, 2026 | 06:08 PM
Adavis1923's Avatar
Adavis1923
5th Gear
5.4 flex fuel
Hi i have a 2007 F150 supercrew 5'.5" bed 5.4 flex fuel with 220K miles. I had the Transmission over hauled a year ago (1.6k miles) it has new Wheel Bearing & Hub Assemblies, Front Lower Ball Joints, Front Upper Control Arms with Ball Joints, Front Sway Bar Links, Front Outer Tie Rods, Front Inner Tie Rods, Front Shock & Spring Assemblies. I replaced my original motor about 4k miles ago with a used 08 5.4 with about 106k miles on it. Of course the timing and phasers are going out on it and was quoted $2.7K to fix it. Im thinking of swapping the motor with a crate motor and wondering if i will be fine to put a regular 5.4 in it instead of flex fuel and if so do i have to change anything major so it fits? Thanks
Old Mar 10, 2026 | 05:05 AM
techrep's Avatar
techrep
You won't have to change anything that I know of. Make sure when you buy your crate motor that it has the upgraded heads and timing set. 08 motors built after 10/07. You will have a great reliable truck with all that's been done.
Old Mar 16, 2026 | 05:53 PM
Adavis1923's Avatar
Adavis1923
5th Gear
Thanks. Do you happen to know a good place to go through for the crate motor by chance? I have looked up a few different places and half of them the reviews aren't the greatest
Old Mar 17, 2026 | 04:40 AM
techrep's Avatar
techrep
Jasper or ford
Old Mar 17, 2026 | 09:17 AM
1956BB's Avatar
1956BB
I put a Jasper crate 5.4 in my 2007 F-150 in 2021. The install was pretty straight forward. Everything from the factory motor transferred over without a hitch. I have added just over 60k miles to the odometer and with the usual maintenance it continues to run strong. Good luck with your project.
Bessie
Aug 1, 2022 09:19 AM
Luckett35
Modular V8 (4.6L, 5.4L)
Apr 16, 2017 09:57 PM
JWA
Dec 25, 2010 12:29 PM
stu02expy
Jan 13, 2009 04:46 PM
Hic
2004 - 2008 F150
Oct 10, 2007 07:46 AM
