Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
E4350 Class C fuel pressure
Old Mar 7, 2026 | 11:27 AM
kevlook's Avatar
kevlook
Just finished a long trip out west and fought the issue all the way out and all the way home. This is a 2004 RV, but the chassis says 2003 and the engine has the 2002 return line fuel system. Left with just under 50000 miles and came home with over 54000.
Random misfires, replaced all boots and 1 coil. Ran great for hundreds of miles.
Yes I have a scan tool purchased on the road. Last scans getting home had pending misfires on 4 cylinders, 2 on each bank. This occurred after stopping to fill up and had to get over some very steep hills.
Already have a new fuel filter and just replaced the fuel pressure regulator on the rail.
Zero pressure KOEO, 29 psi at idle, 39 with vacuum line disconnected. Shut engine off and pressure rapidly drops to zero.
Can anyone explain why starting the engine gets me fuel pressure but KOEO does not? I understand the check valve failing when I turn the key off....
Old Mar 7, 2026 | 12:33 PM
kevlook's Avatar
kevlook
Been studying more, seems I have 2 fuel pumps and the switch in the passenger footwell, where I tried to get power door locks to work before we left.....Hmmmm Figured out mega fuse 17 and relay K to check.
Old Mar 9, 2026 | 10:22 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Cool, did you find the smoking gun?
Old Mar 15, 2026 | 07:23 PM
kevlook's Avatar
kevlook
I am dropping the tank soon. I struggled to get pressure to come up and then it would drop instantly on key off. Using AI, and it was wrong, you have to ask it follow up questions, I have one pump in the tank. The second return line is not a return but rather an emissions line. This correlates with having 3 tubes on the pump. No return for the engine but and outlet and return for the generator.
Red Rascal
18
Jun 14, 2025 02:40 PM
kevin206
Aug 18, 2014 11:05 PM
XSleeper
Apr 29, 2014 01:42 PM
BURNSTOUGHFORD
1997 - 2003 F150
17
Mar 23, 2009 04:21 PM
GammaDriver
May 15, 2002 11:00 PM
