Rear 12vdc outlet.
Old Mar 6, 2026 | 12:34 PM
Montesa's Avatar
Montesa
Rear 12vdc outlet.
2024 Lariat F-350. Any way to set the rear 12vdc outlet on the console to have always on 12v?
Thanks.
Old Mar 6, 2026 | 02:14 PM
5picker's Avatar
5picker
Nothing i know that can be "set."
You could always rewire it.
Old Mar 6, 2026 | 09:20 PM
Montesa's Avatar
Montesa
Bummer, my RAM I traded in left them hot.
Old Mar 6, 2026 | 10:09 PM
Archion's Avatar
Archion
Veteran: Marine Corps
IIRC, the only thing you can do is extend the timeout, requires forscan.
Old Mar 7, 2026 | 07:37 AM
RbrtLls's Avatar
RbrtLls
Back when I had a 2017 F-150, I found the fuse that powered that outlet. I pulled the fuse and made a fused wire a few inches long. I used that fused wire to plug the outlet side to an always hot connection. (I put the original fuse back when I traded that F-150 in on my F-350.)
Old Mar 7, 2026 | 08:18 AM
Archion's Avatar
Archion
This thread might be useful for your needs,
https://www.ford-trucks.com/forums/1...lovebox-2.html
Old Mar 7, 2026 | 02:54 PM
TestPilot57's Avatar
TestPilot57
I have a 100A 12v outlet on the back of my truck, for a DC-DC charger. Not sure if it's live all the time or what (I didn't install it, but maybe it has a solenoid that turns it on/off with the ignition). But it's a good thought, I will have to check into it, and see what kind of adapter is (if) available to plug into it.
Old Mar 9, 2026 | 10:20 AM
powerboatr's Avatar
powerboatr
Thanks.
yes
In forscan you can change time out to not time out
Old Mar 10, 2026 | 07:03 AM
TestPilot57
Originally Posted by powerboatr
yes
How? Set to 0? Or? 9999 seconds is only 2 hrs 46+ minutes.
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}--> PowerPoint Max Timeout BdyCm-BCM 726-57-01 **** xxxx xx-- Seconds converted to Hex (Stock is 1194-75 minutes)
st8yd
Nov 3, 2022 06:03 PM
bushpilot
Aug 12, 2018 07:05 PM
