Spare tire bracket
Old Mar 5, 2026 | 12:17 PM
PaulL68ford's Avatar
PaulL68ford
7th Gear
Spare tire bracket
Hello all.
i am using 30x9.5 BFGs on my 68 f100. Has anyone mounted tires of this size or greater in the stock spare tire bracket (with extended hanging bolts since the stock bracket is too small for 9.5 inch wide tires)?
Would using the existing bracket with longer hanging bolts to accommodate the wider tire cause the tire to hang too low and create issues with ground clearance?
Thanks
Old Mar 5, 2026 | 03:02 PM
RichS2659's Avatar
RichS2659
Probably not as it would only be a couple of inches. 2 or 4wd? Original tires were 8.15 x15 or G78-15's to 72. You will have to lengthen the center sheet metal bar to accommodate the wider tire.
Old Mar 5, 2026 | 03:10 PM
PaulL68ford
7th Gear
It’s a 2WD long bed. The tires that were on it when purchased were 7.00 r15s. Tiny.
eddieo1964
Sep 13, 2024 08:01 PM
Ar1zona
Oct 16, 2020 10:42 AM
nairod
23
Aug 13, 2007 03:56 PM
cat3
2004 - 2008 F150
Sep 8, 2004 03:19 PM
sigtauenus
Nov 2, 2003 03:48 PM
