Wipers keys gone
Old Mar 3, 2026 | 12:39 PM
Squanto's Avatar
Squanto
Wipers keys gone
22 F-350 Limited. I have found the wiper keys have fallen out and I don't have them sitting in the tray.
Is there an actual recall for this or some kind of service notice or something? The dealership found nothing.
Thanks.
Old Mar 3, 2026 | 01:52 PM
BC2019F250's Avatar
BC2019F250
They're only used during assembly and are not needed after that. Mine went missing 115,000 miles ago.
Old Mar 3, 2026 | 02:24 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Yes, there was/is a recall. It stated that they would change the arms out, however when I took mine in, they looked at it and said: "Eh... they look alright." The keys fell out long before that, and of course they didn't swap anything. I kept the paper work though where they refused to swap them despite the recall, and while nothing has happened so far, if anything does, I will let them know!
Old Mar 3, 2026 | 03:07 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Mine fell out before the recall. My truck was in the shop for something else, tech just put some loctite on and reinstalled, never been an issue.
Old Mar 3, 2026 | 07:31 PM
Flatland1's Avatar
Flatland1
I was told they were used for placement in assembly only, splined shaft on drive motor, splined hole on wiper arm........they aren't going anywhere.
Old Mar 3, 2026 | 07:34 PM
Squanto's Avatar
Squanto
Mine are. It doesn't take a lot of force to move the arms and feel the splines skip.
Old Mar 3, 2026 | 07:42 PM
Flatland1's Avatar
Flatland1
Only problem I ever had was when I dumped load of snow off the roof at a stop sign, and turned the wipers on...........stripped the splines on the aluminum arm, drivers side............bought a new one, installed it, the key fell out a few weeks later............almost 70 K on a 2022.........no other wiper problems.
Old Mar 3, 2026 | 07:58 PM
Awar's Avatar
Awar
Squanto, Then replace your wiper arms.
Old Mar 6, 2026 | 05:15 PM
4wd6.7L's Avatar
4wd6.7L
There was a recall but it was NOT do to missing keys. As stated by others, the keys main purpose is to easily position the arm during assembly. The recall was for a batch of arms that had improper spline height do to manufacturing reasons. The recall involved specific date ranges. If the dealership did not see that recall associated with your truck, then it doesn't apply to yours.
If you buy replacement wiper arms they will come with new keys. If you do not want the new keys to fall out, you'll have to use some sort of adhesive to help assure thay they stay put. The keys have been gone from my wiper arms for at least 5 years without issue.
Old Mar 7, 2026 | 09:15 AM
Lariat Driver's Avatar
Lariat Driver
Veteran: Navy
The woodruff keys fell out of my 22 F-250 wiper arms probably within a year or 18 months of getting the new truck. I found them lying in the recess under the wiper and decided to glue them back into place. My theory was the splines will keep the wiper moving but the added key will provide extra drive force if needed and keep the splines from rounding off. YMMV
Old Apr 24, 2026 | 02:27 PM
Squanto's Avatar
Squanto
Well, just a couple days ago I got a recall notification for this. It said they won't have parts for it until June/ July.
Old Apr 24, 2026 | 03:00 PM
4wd6.7L's Avatar
4wd6.7L
What is the recall#? I have yet to see any wiper arm recalls directly related to wiper arm keys. Both wiper arm recalls (there have been 2 that I'm aware of) have been do to manufacturing defects of certain batches. The first recall wiper arms were found to have improper spline height. The most recent appears to be a defect in the latch retention plate and spline height.
Old Apr 24, 2026 | 08:59 PM
Lariat Driver
Veteran: Navy
I also got the wiper arm recall in the mail three days ago for my '22. Safety recall 26S24 or NHTSA recall 26V204 for those doubters out there. My truck was not covered by the earlier recall for the wiper arm spline inspection that @chadstickpoindexter had done on his truck.
My wiper recall notice also said Remedy Not Available until the end of June. I have three other outstanding recalls with no remedy available. The first one came out July 2025 with an expected remedy available in the third quarter of 2025 (July, August, September). That didn't happen. These three recalls are all software related so that looks like a perfect candidate for an OTA remedy rather than a trip to the dealership. It's good that Ford is identifying problems but they need to be developing solutions and remedies to go along with the Recall list.
Flatland1's Avatar
Flatland1
Yes, I agree.........the key would add more support between the wiper arm, and the wiper motor..........but really all the keys do is put the wiper arms in the correct position.........
Old Apr 25, 2026 | 10:33 AM
01tundra's Avatar
01tundra
Originally Posted by Lariat Driver
I also got the wiper arm recall in the mail three days ago. Safety recall 26S24 or NHTSA recall 26V204 for those doubters out there.
I got the recall letter last week as well, for my '22......
