Options questions
The Security Perimeter option states: "When activated by your Ford Dealer, the Basic Remote Start System is also included; start your vehicle from up to 300’ away".
So does this mean it also includes the remote start,...or do I need to order that separately and the other option is more of an alarm??? I am a little confused!
Thanks!
I will try a different build site,....any recommendations? (I believe I used Edmund's years ago but it has been some years since I had to do this again!)
Saying that, I did go and "build" a truck to see what you are talking about. This is what it says:
Remote Start and Vehicle Security
Vehicle Security System - Ford Perimeter Plus
$255S8Use your factory key fobs to arm and disarm, helps provide contents protection too- When there’s sufficient impact to the glass or a body panel, the 2-stage shock sensor determines whether to issue a warning chirp or full alarm
- When activated by your Ford Dealer, the Basic Remote Start System is also included; start your vehicle from up to 300’ away
- Parking lights remain on during remote start so you know the engine is idling
- Run time and other features are easily programmed through the vehicle’s driver information center
Based on this, it does look like/sound like remote start is included, but they also state that it may have to be activated by the dealer. When ordering a truck, some items are dealer installed options, and the Perimeter Plus option sounds like one of them. This would mean that when the truck arrived at the dealership, they would then install the package (likely just plug in a module), and would then activate it (turn it on) using FDRS. When turning it on, it must also require the remote start feature to be turned on as well. (These things are simple to do as the option are already in the truck and a simple check mark can turn features on and off, but you need either FDRS or Forscan to do so.) So yes, remote start is included, but you may not get the FOB with the remote start button...
After reading another thread (HERE) it sounds like the non-remote key FOB can also be used to remote start the truck by pressing a sequence of buttons (LOCK - UNLOCK - LOCK) rather than having the dedicated remote start button like the remote start FOB has. So, this may be a difference in the 2 packages. With the remote start option, you get the remote start FOB. With the Perimeter Plus option you may only get the basic FOB, which uses a button sequence to remote start.
Also, keep in mind, any of these trucks can be remote started using the FordPass app even if you don't get the remote start or the Perimeter Plus option.
So, based on this, you don't need to add the remote start, just add the Perimeter Plus option. It won't force you to add the remote start option but you will probably only get the regular FOB.
Something else, I don't know what trim level you are looking at, but remote start is a pretty common feature now days. I think it comes standard on the XLT Premiums and up... so if you are looking at say even a basic Lariat, all of this is moot because that trim automatically include remote start.
But basically to recap,...I actually "can" order both options, but I will be paying twice for the remote start,...but I will also get an upgraded fob for the basic remote start option if I did so. (My 2016 requires me to click LOCK twice then REMOTE START button twice as it is,...so just getting the Security Perimiter/Remote start option would be fine for me as I am used to pushing more than 1 button already.)
Thanks again, really appreciate it.
Also, I ordered my 2022 as an XLT Value and I love it! They don't even offer a Value package anymore I don't think, so the base XLT is probably the same thing now. And I will say that if it is still an option, the keypad on the door has been my favorite add on! I wouldn't buy another one without it! I rarely use my remote start, but I use that keypad everyday!
Unfortunately, they deleted it for 2025, but then added back on for 2026,...but only for crew and extended cabs, But the cheap "wireless" one is still an option, so I guess it's better than nothing!
It is frustrating though that the keypad and larger screen options are only available on the XLT PREMIUM trims, which require the Crew/Extended cabs, and I am 100% set on a regular cab.
- The app, which is free, and available for all trucks, even the ones without the remote start option or the Perimeter Security package. Of course you do need to download the app though.
- The remote start key FOB. Comes with the remote start option.
- The non-remote key FOB. Most likely this is the one that comes with the Perimeter Security only package
The remote start somebody else mentioned is just a push of the Remote Start FOB,...and the perimeter plus has a different FOB that you need to use a sequence.
My 2016 needs the LOCK button pushed twice,...then the Remote button pushed twice. Very simple!
I will just go with the Perimeter plus option,...
Thanks everybody!
