Oil leak
Old Feb 27, 2026 | 12:04 AM
saauvenshine's Avatar
saauvenshine
Oil leak
Have a 1954 ford truck all original with 239 ohv and 3 speed standard trans. Was getting a pretty good puddle of oil underneath after each drive so replaced rear oil seal. I have done several over the years with good luck. After changing still had leak as I staggered the neoprene seal and oil them up pins drove in good on side seals as well. Got under truck and looked and oil did not look like it was coming from rear main but dripping out the small bottom hoe in the fly wheel cover pan. Is there a front seal on trans input shaft that could be leaking.
Old Feb 27, 2026 | 04:30 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
You don't mention which 3 speed you have for me to get specific parts, but there is an oil slinger disc behind the front transmission bearing - there is no oil seal.
Old Feb 27, 2026 | 09:14 AM
Steve's Avatar
Steve
You "should" be able to tell if it's engine oil vs gear oil by the odor. That said, try dropping the cover and see what the flywheel and clutch look like. The rear main seal retainers on these things can be problematic. They have to be staright and concentric. It's hit and miss replacing the RMS on a Y block in the vehicle. Everything has to be oil free so the the side seals need that dab of RTV can seal.
Doubleclutch
13
Mar 11, 2025 07:44 PM
billygoat
Jan 29, 2009 10:53 PM
Caleb H
Oct 18, 2008 07:53 PM
Steve70
Apr 17, 2005 09:49 AM
EceaRyder
Apr 30, 2003 05:36 PM
