An issue I ran across...
1980 was a transitional year, truck had both from the factory.
I hope my truck is done transitioning.
No hard and fast rule about what to expect where. In general terms, if something predated the transition, it tended to stay SAE. Think female threads in an engine block, for example.
If a part was introduced during the transition, it typically had metric fasteners. For example, think of a bracket on the engine. If the bracket had any female threads, those were usually metric. But the bolts into the block usually were SAE.
Be aware there are plenty of exceptions to this “rule”. Some components got more metricky (that’s a word) in later years. Say you’re replacing a timing cover. It may have originally had female SAE threads for the water pump bolts. But later years may have gone metric. An aftermarket parts supplier would like to keep inventory simple, so they only offer the full metric version. You could remove SAE bolts, replace the timing cover, and suddenly the original bolts won’t fit. I’ve learned the hard way to test fit those bolts from the comfort of my workbench versus trying to install them one-handed in blind quarters.
I have found motor / trans / rear axle were SAE and everything else was metric when rebuilding my truck, cab off frame so just about every bolt was touched.
Just roll the tool box over to the truck when working on it as it will take every wrench & socket of both SAE & Metric
Dave ----
We like to make learning fun
Dave ----
On a more serious note, you mentioned
to someone else a while back to check
the clutch pivots or something? Can you
refresh my memory?
https://www.google.com/search?sca_es...koIEAIYAiACKAI
You really need to check the whole clutch linkage system.
Starting at the pedal on the other side you will see the "arm" that bolts to the clutch shaft. You need to check this where the rod connects to it and goes through the floor.
I believe there should be a plastic bushing but if not make sure the rod and hole are not worn.
Bottom center is the part that bolt to the shaft of the clutch pedal. If you look closely the round hole is not round.
This is 1 end of the rod that connects to the "arm" and goes through the floor to the cross shaft. Both trucks the rods looked like this.
Now the rod after it goes through the floor connects to the clutch cross shaft or some call it a Z bar on other models.
This cross shaft where the rod connects and where the fork rod connects make sure the holes and not egg shape.
Now the BIG ISSUE is the pivots for this cross shaft. If you look at the first picture I posted at the top is the motor side pivot, there is one on the frame side also.
That pivot screws into the block and there is a plastic bushing that fits on it and held with a snap ring.
The pivot on the frame side is a bracket type and bolts to the top of the frame rail. There is a bushing on that side also but cant remember if the bushing goes in the shaft or the pivot now?
There are also felt seals to keep dirt out. LMC has a break down of how this all fits together.
If the plastic bushings fail the cross shaft then rides on the metal pivots and they wear down like in the top picture.
Because you CAN NOT GET this pivot I had to fix what I had with what I had.
I welded all the parts and then grind and hand filed them back into shape and they worked ...........
Till they stop pivoting
Fixed with a bolt with the head cut off and welded to the main pivot. Remember you CAN NOT get this part anymore.
Bolt threads welded to the main pivot and it worked .............. till it didnt
The weld did not go deep enough with the welder, 120 MIG w/gas.
So the fix was again head cut off bolt and drill the pivot and threaded part to install a roll pin and do a better job welding if I could.
Be this time I did find a OEM pivot on Ebay and for not a lot of money as a back up.
Well I needed it as this one broke too
But I forgot where I put the new pivot so was down for a few weeks pulling the garage apart looking for it.If you have a good one or 1 you can get measurements from and have a good machine shop they could make one or a few and you could sell the others.
Heck if I had the machines I would give it a try to make one as I dont think it would be all that hard.
IIRC the thread was 9/16 course, yes a strange size but I was able to find bolts at the local hardware store.
So make sure the plastic bushings for the cross shaft, frame to motor, are in place so the shaft does not damage the pivot.
Dave ----
muffler, even very little coming out of the holes and cracks. I never figured out where
the exhaust was coming out. Someone mentioned a reversion valve on the exhaust,
but danged if I know where it is. It's all coming off, then I'll know. The catalytic converter
was obviously plugged up as well. I still have not found any platinum. lol
