94 460 Water Pump Hose Size
Id recommend using either an oteiker style clamp or a sourced tension clamp for the reinstall, the hose will last substantially longer without the biting of the worm gear into it over time(just a recommendation for the OP)
but 5/8 looks close to the size, quick google search of 460(albeit older carbureted ones) shows 5/8
The 460 to my knowledge even with serpentine never did reverse flow or anything? So that means the water pump should be the same as the older ones, which means the port is probably the same, so the hose is probably 5/8
66F250_4x4
Jun 11, 2021 09:04 AM
F350moneypit
Jul 16, 2015 11:23 AM
SoCalAngler
Jul 1, 2014 10:04 PM
