Driver door handle doesnt work
Old Feb 15, 2026 | 01:33 PM
MarcGodin's Avatar
MarcGodin
3rd Gear
1948 F1, drivers side door handle wont open the door. Inner handle works great. Tips on how to fix/ disassemble the latch box?
Old Feb 15, 2026 | 01:56 PM
abe's Avatar
abe
Hey , Marc, I can't help you with a 48 but welcome to FTE the best Ford truck forum on the World wide Web!
While you are waiting for an answer post some pictures of your truck.
Old Feb 15, 2026 | 02:18 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Is it locked? Does the extra handle rotate?
Old Feb 15, 2026 | 05:33 PM
abe's Avatar
abe
Thanks for the pics. You got some great backdrops.
Old Feb 15, 2026 | 06:13 PM
FortyNiner's Avatar
FortyNiner
Removing the latch mechanism from the door is the easy part - removing the side window glass usually helps. Getting inside the mechanism itself is about guaranteed to break the danged tabs that hold the thing together.
Smarter folk have successfully repaired the worn bits inside. I failed and bought a new mechanism from Midwest Early Ford - which fit perfectly and performed flawlessly for a number of years.
Old Feb 16, 2026 | 08:27 AM
52 Merc's Avatar
52 Merc
Welcome to the forum, Marc! Nice truck. You introduced it as an F1, but it looks Mercury. Which is it really? We need a little more info the help with your diagnosis. What does the handle do, exactly? The handle on these trucks is as simple as it gets. It's a square shaft stuck onto the handle, which fits into a square hole inside the latch mechanism, which rotates the latch release. Something inside there is obviously malfunctioning. The handle is attached to the door by one round head fine thread machine screw located behind the weatherstrip, inline with the handle. If you carefully peel back the rubber, you'll see a hole in the door shell and the screw is inside there. It's also commonly rusted and very hard to remove, fyi. Lubrication and great care is recommended in trying to remove it, but it has to come out if you're going to go inside to remove the latch. It's step one. Good luck, let us know what you find.
archer472
Feb 16, 2026 05:01 AM
hutchie
52
Apr 5, 2017 12:01 PM
Joker50
May 28, 2008 03:29 PM
