Please help identifying this relay
Old Feb 15, 2026 | 11:35 AM
MarkAM's Avatar
MarkAM
4th Gear
I have a 1985 F150 and can't determine what this relay is called. It is located between the ashtray and the steering wheel at the bottom of the dash near the EEC wiring box/ harness. I have a mechanical fuel pump so I am suspecting it is the EEC/ ECM relay?!? The reason for this is that I need to replace it because it continually clicks after the truck is off and drains the battery. It is also very difficult to get off of the brown pigtail/harness (still haven't gotten it off} A picture is attached. Thank you!
Old Feb 15, 2026 | 12:22 PM
Max Capacity's Avatar
Max Capacity
Go to your local NAPA and get the replacement from them. They will know. I think it's a common part used in a number of places on the trucks.
Try EEC power relay.
Old Feb 15, 2026 | 12:26 PM
Max Capacity
You may find it here ... Make sure I chose the correct engine
https://www.garysgaragemahal.com/1985-evtm.html
Old Feb 15, 2026 | 12:43 PM
Franklin2's Avatar
Franklin2
The colors do match the EEC relay in the diagram above. The white with blue dots wire is what powers the relay to on. So that would be what is making it click on and off. The diagram above says it comes from page 29. Here is page 29.
You can see the white/lightblue that is making the relay click is also hooked into the coil + wire. I would see if I had voltage on and off there when it was not supposed be there. You can see the wire from the first diagram comes from the lower right of the diagram in this post.
Old Feb 15, 2026 | 12:45 PM
MarkAM's Avatar
MarkAM
4th Gear
Thank you very much Max Capacity! You did choose the correct engine and I haven't seen this diagram before. I believe you are correct. Many thanks for the Napa referral as well. I'm off on my mission now.
Old Feb 15, 2026 | 12:57 PM
MarkAM's Avatar
MarkAM
4th Gear
Thank you Franklin2! I will locate the White/LtBlue wire coming out of the EEC Dist. Module and test. It doesn't seem to be hooked up to the relay but that could be the issue why it is not getting the resistance to shut off. Dang, you guys are good! Much appreciated.
Old Feb 15, 2026 | 01:33 PM
kr98664's Avatar
kr98664
You can see the white/lightblue that is making the relay click is also hooked into the coil + wire. I would see if I had voltage on and off there when it was not supposed be there...
As much as it pains me to admit, I must agree with Dave. The relay itself is not the root cause of the problem. The control circuit is weakly energizing the electromagnet (inside the relay) when it should not.
For a similar example off the top of my head: You shut off the headlights but the bulbs remain dimly illuminated. That is not a bulb problem.
Old Feb 15, 2026 | 02:06 PM
Max Capacity
I wonder, if he has a sticky ignition switch in the colume...? Maybe spraying it with a WD40 might help if that's what the issue is... ?
I'm just guessing... Dave and Karl are the smart guys.
Old Feb 15, 2026 | 03:46 PM
MarkAM's Avatar
MarkAM
4th Gear
Thank you guys for all of your expertise. Lots of good ideas to look at and diagnose. When it finally gets resolved. I will let you know what it was.
bmwmike
15
Aug 24, 2025 07:54 AM
Flyboy1100
Apr 29, 2020 06:35 PM
05 XLT 60 PSD
Dec 31, 2012 07:36 AM
danos94
Jul 22, 2010 12:49 AM
Lifted94XLT
Kansas Chapter
30
Feb 29, 2004 12:45 AM
