Sponsored by: Real Truck
Forscan bms reset
Old Feb 15, 2026 | 09:09 AM
tuckerdog's Avatar
tuckerdog
3rd Gear
Forscan bms reset
Hi there new here I bought the Forscan the 1 thing I wanted to do is , after installing new batteries is reset the bms for my 2016 f350 it is not list in Forscan
I have done the 5 click high beam and 3 brake thing but that will not work any thoughts Thanks
Old Feb 15, 2026 | 05:03 PM
ifrythings's Avatar
ifrythings
2016 Superduty trucks don’t have BMS, only the F150 had BMS in this year.
Old Feb 16, 2026 | 09:04 AM
WWR's Avatar
WWR
Yep you shouldn't have BMS (and hopefully not IBS!) so as God intended, just install a new battery(ies) and go
Old Feb 16, 2026 | 12:32 PM
tuckerdog's Avatar
tuckerdog
3rd Gear
Thanks I quess that,s why it is not listed in Forscan But this all started with Message [ System off to save battery ] So I installed new batteries after 10 years but I have the battery light showing up in dash--- and it still gives me system off to save battery but that only happens after I drove the tuck for hr,,go shopping come back in truck start it and get message I have info on this truck if you want Thanks agian
Old Feb 16, 2026 | 03:18 PM
WWR's Avatar
WWR
I'm not sure about your message but these trucks have an EXTENSIVE history of the batt light from a failing alternator. Note they'll still charge but something -- presumably the regulator? -- isn't whispering sweet nothings to the PCM, triggering a light. Aftermarket alternators perpetuate the problem and many a batt light has been eliminated by using OEM (even used).
That said, don't go buy an alternator based upon my anecdotal statements. More diag should be performed before spending a dime on parts.
Old Apr 10, 2026 | 07:24 PM
tuckerdog's Avatar
tuckerdog
3rd Gear
alternator charging too high
hi still having problems with my f350 6.7 I have been getting this message system off to save battery I used a volt meter on battery engine shut off and is 12.3 volts start the engine and it now is 16.44 volts a little high
whisper
May 25, 2023 10:24 AM
Flyct
Jun 21, 2022 11:33 PM
lowbed dud
Vehicles for Sale
Dec 31, 2015 01:58 PM
big3g
General Automotive Discussion
Mar 7, 2012 05:55 AM
L.TONY F350
Aug 8, 2006 04:56 PM
