Help! Rear End
Old Dec 9, 2003 | 05:13 PM
joegeoghegan317's Avatar
joegeoghegan317
Question Help! Rear End
I already posted once about my truck jumping, and you guys said it should be the u joint. I already replaced it and it still does it. I think that it may be the rear end, (GEARS?) So right now im in the process of taking the center section out. I have a ford 9 in. I took off the 10 bolts that are holding it in place... and thats as far as i have gotten. It wont come off.... Am i forgetting something. Ive tried to pry it off but it wont budge. Please help and give some helpful hints. Thanks....
JOE
Old Dec 9, 2003 | 05:20 PM
BB's Avatar
BB
Ummm, did you pull the axles yet?
Old Dec 9, 2003 | 05:58 PM
heep70's Avatar
heep70
Does it have a locker in it and drum brakes? I have a D60 in the back, but this is something to think about. Mine was jumping when I applied the brakes. Found out that one side of the drum brakes in rear was way lose and the other side was adjusted right. When I applied the brakes, one side started braking and passed it back through the locker to the other side that was not braking, trying to lock that side up. Being there is some give in the locker, the wheel would roll a bit then stop, over and over.
Old Dec 9, 2003 | 06:00 PM
joegeoghegan317
I got it off.... Im letting it drain now... Im just going to take the center section out to see it there are any teeth missing on the gears because thats what it seems like to me... If there are I might need help putting in a trac loc. Thanks guys.
