T5 swap in '47 1/2 ton (jailbar)
Old Feb 6, 2026 | 03:16 PM
tlktchr's Avatar
tlktchr
Trailering
Has anyone here made this swap? I have just about everything figured out except for the speedo gear. Does anyone know which gear I need? T5 from a '91 S10, mated to a 239 flathead. Everything else is bone stock.
Old Feb 7, 2026 | 10:00 AM
51504BAT's Avatar
51504BAT
Hopefully GB Sisson will see this and chime in. Or you can ask over on the Ford Barn, He's on there more often. He installed a T5 behind a Merc in his homemade woodie wagon. He is pretty much all things jailbar.
Old Feb 13, 2026 | 08:46 AM
tinman52's Avatar
tinman52
Welder User
The '91 T5 uses an electric signal type speedometer. To use a cable driven speedo you must switch to the early T5 tailshaft/housing, or use a converter box
old'skewl
Dec 13, 2011 07:44 PM
cjg1999
Pennsylvania Chapter
Nov 10, 2007 10:19 AM
