Compatible trans fluid
Old Feb 1, 2026 | 01:24 PM
Garbageman 134's Avatar
Garbageman 134
A couple of weeks ago when it was really cold outside I was pulling out of my driveway and I heard a crunching noise which I thought was just ice but when I got to the corner I heard a pump whine for a couple of seconds and then the transmission crunched as it downshifted to first gear.
Today as I was pulling into a parking lot I hit the gas, the RPMs came up, the truck did not move for a couple of seconds and then bam, the transmission engaged. I'm guessing it's low on fluid which is odd because it's never been opened up and it's never leaked but I cannot find Motorcraft ulvf fluid in my area. Is anything else compatible?
Old Feb 1, 2026 | 02:14 PM
Superdave71's Avatar
Superdave71
Rock auto or your local dealer
Old Feb 1, 2026 | 03:29 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
MERCON ULV is a formulation, as such, any brand of MERCON ULV is compatible, doesn't have to be Motorcraft.
I used Valvoline MERCON ULV when I did the new pan on mine.
But, if your truck has no obvious signs of trans fluid leaks, then very likely some other issue.
I would check the level first before buying any fluid or adding any.
Old Feb 2, 2026 | 05:04 AM
Chris 86's Avatar
Chris 86
I had a similar issue happen to me on my 2020. ended up needing a transmission rebuild. Burnt clutches and drum bearing that went for a walk.
Old Feb 2, 2026 | 07:06 AM
HorizontalHunter's Avatar
HorizontalHunter
Anyone running Amsoil in their Super Duty transmissions?
Bob
Old Feb 2, 2026 | 08:41 AM
Joe T's Avatar
Joe T
If you have chatgpt it can pull up all the compatible fluids. You can review them from there.
I generally look at viscosity at 100c. I like to be on the high side.
Old Feb 3, 2026 | 07:12 AM
Rooster_Luck's Avatar
Rooster_Luck
10 speed?
Old Feb 3, 2026 | 07:55 AM
HorizontalHunter
Originally Posted by Rooster_Luck
10 speed?
The OP doesn’t specify so it makes it hard to answer their question. My question regarding the Amsoil was specifically referencing the 10R140.
Bob
Old Feb 3, 2026 | 09:10 AM
2021F350's Avatar
2021F350
Bob
Yes, I am... Also in the transfer case and diffs... Seems to have gained about 0.5 to 1.0MPG & makes it up hills usually 1 gear higher, meaning 9th instead of 8th and so on...
Old Feb 3, 2026 | 09:59 AM
HorizontalHunter
Always good to hear. I am a fan as well.
Bob
MojaveRed
Nov 1, 2025 07:41 PM
Whoknew1
1997 - 2003 F150
13
Feb 4, 2020 11:56 AM
Monica Allen
Jun 30, 2018 08:13 AM
fordman19762003
Jun 4, 2018 07:58 AM
Becca_78
1983 - 2012 Ranger & B-Series
Sep 23, 2009 06:53 PM
