Driver's seat quit heating/cooling. Checked with Forscan, pix are linked, looks like the DCCSTAT has failed. Is this the control module under the driver's seat near the front that the TEDs are connected to?
Passenger seat heats and cools properly and ground terminal is NOT burned.
I had this happen. I think my control module is under the pass seat. I did a visual on it and did not see the telltale melted connector, so I ordered these parts:
DU5Z-19N550-D
GU5Z-19N550-D
Honestly, I probably only needed one of them but just said F-it, I have the seat out. Replaced them and everything worked as it should. Got the parts from Tasca for $80 and $105 respectively.
