Engine question
Old Jan 29, 2026 | 07:02 PM
Daniel Yosef's Avatar
Daniel Yosef
Engine question
Hey guys, I got my 68 project. It got the 390, ran a compression test today, got about 150-160 all across with 2 cylinders around the 135. How is it for this engine?
after doing that I set my timing.. I was a bit advanced from 10 btdc so I backed it off a bit , runs pretty good but I feel I got a bit lacking power still and a little lag when I actually driving the truck when I first hit the pedal.
any help and advices will help.
also, is there an adjustment to make to get the clutch to engage a bit higher?
Old Jan 29, 2026 | 09:32 PM
blue68f100's Avatar
blue68f100
Those 2 low compression cylinders are hurting you on power. If you have access to a cylinder leakage gauge set, I would run it to find where the low pressure is bleeding off. Could be a broken ring on leaking valve. These old engines were pretty gutless when it came to power. The low compression (8.5:1) really hurt them. Modern 4 cylinder engines generate more power than these big v8. They do develop low end torque due to the long stroke.
You can play with the clutch rod adj some. Too loose and you want be able to fully disengage it, but will raise the petal position for feel.
Old Jan 29, 2026 | 09:57 PM
Dkwautounion's Avatar
Dkwautounion
Trailering
Have you ever driven a 390 with the same rear end gear ratio that you have so you have some to compare it too? Has the carb been rebuilt if its been sitting? Maybe the jets are clogged or the accelerator pump isn't working correctly.
Old Jan 30, 2026 | 05:32 AM
manicmechanic007's Avatar
manicmechanic007
Compression spec is 85 percent of the highest
Means at 100 the low one at 85 is ok and 84 is not
The low one must be within 85 percent of the highest one
Yours 160 / 135 is .84375 borderline fail for a misfiring cylinder
I'd run it and live with it till she puked
Old Jan 30, 2026 | 05:42 AM
manicmechanic007
I would at least pull the valve covers and make sure there are no bent pushrods
Agree strongly about getting the carb working properly
We used to just throw those old ones on the I/M machine to check a few things out
If the spring on the vacuum advance gets weak, the HC's will peg 2000 and they run like puke with a bad spring
Same with the power valve, if the CO is at 10 percent yours leaks
These days might just want to overhaul the carb every few years and keep a good new power valve in there
Most important is the choke and the choke pull-off also the float level and condition of the float
What altitude are you at?
Generally, you add 2 degrees of ignition timing per thousand feet of elevation
Here in UT at 5000 feet, I run my 68 Camaro 350 at 14 degrees
Old Jan 30, 2026 | 02:46 PM
whitey68's Avatar
whitey68
Your truck sat for a looong time, all you have is idle time on it so far. A ring could be stuck on those two cylinders.
When it's drivable put 100 miles on it with the Marvel's Mystery Oil in it, then if you feel you need to check it again and compare notes.
BTW ..10-12 degrees btdc is fine, she should run real happy around there as long as you have the carb dialed in.
Old Jan 30, 2026 | 02:51 PM
manicmechanic007
+1 for the Marvel Mystery Oil
You can also use a quart of trans fluid with an oil change
Unstruck a pressure relief valve in the oil pump of an old Z-28 that way
Old Feb 1, 2026 | 06:27 AM
Daniel Yosef
Thank you for all the replies. Very much appreciate it
I went ahead and ran another oil change (after fixing it, letting it idle a bunch and adjusting everything) oil looked decent. Put in 10-30 and 1 bottle of marvel to sit in those valve areas overnight. She sounds pretty good. Time to run it a bunch more when weather gets normal again…
On another topic I’m trying to get my original gauges to work. I have nothing but speedometer at the moment. Any suggestions what to look for?
Old Feb 1, 2026 | 06:36 AM
Daniel Yosef
my radio as well, seems to get power, can’t hear a sound.
Old Feb 1, 2026 | 06:43 AM
blue68f100's Avatar
blue68f100
Do you have any power to the fuse block? Lights working? Check the wiring on the ignition switch. If your has the round pins they will loosen up and get bad contact. Most convert to the newer blade style. The same things happens with most all the electrical connections on these old truck. Unplug connections and check for oxidation, clean as needed and reconnect.
Old Feb 1, 2026 | 06:46 AM
Daniel Yosef
I got fuses power, got headlights and taillights. Got dome lights and wipers. I got radio signal just no sound. But no gauges at all. I checked the sending unit for gas, all seems good, new float, but no power to the power cable..
Old Feb 5, 2026 | 08:26 PM
whitey68's Avatar
whitey68
Any updates
Hey Daniel,
any updates on your truck, made any progress?
Jeff
Old Feb 6, 2026 | 12:02 PM
1browski's Avatar
1browski
As far as the radio goes, if its the original speaker, its probably blown. On my 70 f250, the am radio works. My dad cranked the volume up fast and it was done. Its still in there. Get to it eventually. Swapping the speaker out will be a pain.
Old Feb 7, 2026 | 05:58 AM
Daniel Yosef
Originally Posted by whitey68
Hey Daniel,
Jeff
hey! Yes sir, plenty of work done. It’s running better , I still have trouble with the rpms , the truck seem to run on high idle almost no matter what. It’s timed, I adjusted the carb, no vacuum leaks. Still can’t seem to idle her down.
Old Feb 7, 2026 | 07:49 AM
blue68f100's Avatar
blue68f100
Make sure the butterflies on the carb are not binding and are fully closing. You need to remove the carb to confirm this. To set loosen the butter flies and let them self align before tightening with throttle stop full off. Also the choke idle cam can stick and hold the engine at a faster idle. If this is a automatic, check the down shift linkage for binding. I've seen it on rare occasions that it does not let the butterflies close completely. If your has the dashpot/damper on the throttle stop, you may need to back it off some.
