P0300 2013 5.0
Old Jan 24, 2026 | 09:15 PM
rsylvstr's Avatar
rsylvstr
P0300 2013 5.0
136k miles
plugs, boots and springs 10k ago
always run top tier fuel.
independent changed my oil but used 5w30 for the first time. Stomped on it tonight (it is -1* F here in central NY and engine was coldish), CEL flashed like six times and went on.
hit the on ramp and stomped on her and it flashed again.
P0300 and no other codes.
runs fine.
read a lot tonight about it.
is the change in viscosity just a coincidence? I have always run 5w20.
Old Jan 25, 2026 | 06:56 AM
nitebreeze's Avatar
nitebreeze
I wouldn't think engine oil viscosity change could cause a misfire. Your new oil still has the same fairly good cold temperature viscosity. Even if the oil change from synthetic to non synthetic occurs, I wouldn't think that can cause a misfire. I am no engineer so don't listen to me. Extreme cold can cause problems, maybe it was something else. Hopefully it was only related to the cold and nothing worse. I think this is worth investigating further. I had a couple of times my Expedition with 3.5 EB gave that same pattern of CEL during extreme cold and it went away and never showed any problems that I saw. I used to start needing to replace coils around 80k, so it could have been related but I didn't know it. My F150s with 5.0 never did this but they weren't daily drivers. I also often had the factory shocks feel like they had no damper when extremely cold. -26 at my house last night a little northeast of CNY.
Old Feb 2, 2026 | 07:04 PM
rsylvstr's Avatar
rsylvstr
Interestingly, I have not been able to duplicate it.
Old Feb 21, 2026 | 09:06 PM
rsylvstr's Avatar
rsylvstr
Now P0305. So I know where to start.
Programmed back to stock.
Old Feb 22, 2026 | 04:53 AM
WHanson's Avatar
WHanson
Doesn’t seem like a coincidence. The variable valve timing operates on oil pressure to advance timing of the camshaft. I’d revert back to 5W20 and see if it goes away.
Old Feb 24, 2026 | 08:30 PM
rsylvstr's Avatar
rsylvstr
Agreed. For now just taking it easy.
Aaronw12
2009 - 2014 F150
Feb 29, 2024 10:09 AM
Straightgrain
Sep 6, 2018 06:14 PM
treyw147
Modular V10 (6.8l)
Dec 15, 2016 07:43 AM
cdorr0
2009 - 2014 F150
Mar 19, 2015 04:32 PM
Growl60
16
Jan 25, 2010 11:50 AM
