Strange Drive Vibration
Old Feb 19, 2026 | 07:52 PM
unleashd's Avatar
unleashd
ForScan Lite on my iPhone does not pick up any misfires or injector faults. SnapOn scanner at my regular shop doesn't pick up any faults either. Truck idles normal. I get the shuddering/vibrations only when accelerating.
Old Feb 20, 2026 | 06:20 AM
Freedom-over-safety's Avatar
Freedom-over-safety
Just to throw another possible cause in here, i chased a vibration for quite a while before accidentally fixing it when i upgraded to a manual transfer case. Apparently a TC bearing was bad and causing a vibration at light throttle on the freeway.
Old Feb 24, 2026 | 08:27 PM
DustyEx's Avatar
DustyEx
Trailering
UPDATE
Think I have nailed down the issue. 97% sure it is poor coils and ignition causing this. This weekend going through each cylinder while engine was running I unplugged 1 coil at a time to pinpoint 1 running rough. I found 2 coils where the wire harness connector was loose! I secured them and it was instantly better. However, after I drove it a while it came back.
what I’ve found is that when the engine is colder it runs good. As it warms up, ignition gets poor and starts getting the misfire and shudder back. It only starts happening after engine is fully warmed up and running a while. So, I’m changing all plugs and coils with Motorcraft and will see what happens.
Old Mar 14, 2026 | 07:30 PM
DustyEx's Avatar
DustyEx
Trailering
Resolved!
It was definitely a rough running misfiring engine. Replaced all plugs and coils. Then still had an issue. Found a previous owner had replaced one of the wiring connectors from engine harness to coil and that wiring splice was causing issues. Been good for a while tank of gas now. And runnning smooth and strong.
Old Mar 14, 2026 | 09:26 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Glad you got it figured out, wiring problems can present the most unusual symptoms
Old Mar 16, 2026 | 12:59 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
immediately though misfire on reading initial post. glad you found it.
if it pops up again, verify your cowl seal isn't split and draining water onto the driver COPs. My V-10 had an issue with that. #6 & #8 would flood and ground out after a rain. Until i did the cowl fix mentioned in the Tech section and made sure the COP boot was securely fastened and lubed. Just a FYI for the future.
grooobz
13
Feb 21, 2022 10:35 AM
ForTiLLiaN
Jan 31, 2006 12:40 PM
Bdyzr1
2004 - 2008 F150
Jan 27, 2005 08:10 PM
dand98625
Jan 13, 2004 02:47 PM
Geoboy
Modular V10 (6.8l)
Dec 14, 2003 10:58 PM
