Hard starting 7.3 IDI
Old Jan 16, 2026 | 10:16 PM
TractorJack's Avatar
TractorJack
7th Gear
I have a 1993 7.3 IDI. I checked the glow plugs and they all checked out good. I put an injector return line kit in it to. It is still hard starting though. I was wondering if there are any other weak points in the fuel system for air intrusion. When it is 30 degrees it is glow plugs, turn over, glow plugs, turn over, and it usually starts. I have to do that up to 4 times depending on how cold it is under 30 degrees. I do not want to wear my batteries and starter out so I just want to fix the issue.
Old Jan 17, 2026 | 12:44 AM
ihc1470's Avatar
ihc1470
Block heater work and if so does it start any differently then just using glow plugs.
Old Jan 17, 2026 | 09:34 AM
TractorJack
7th Gear
Yes the block heater does help it start better. It usually only involves.glow plugs and turning over once for it to fire off with block heater.
Old Jan 17, 2026 | 10:38 AM
Olds64's Avatar
Olds64
When you do glow plugs, turn over have a buddy bleed the fuel filter to make sure it's a solid stream of fuel that comes out.
Old Jan 17, 2026 | 11:10 AM
ihc1470's Avatar
ihc1470
My experience has been if block heater is working good that if plugged in a couple of hours you do not even need glow plugs. Do as Olds64 suggest and check for air at fuel filter. If no air and if it starts with block heater and no glow plugs I would suggest going back over the GP system. How did you test it the first time, ohm meter, test light, amp meter?
Old Jan 17, 2026 | 11:32 AM
TractorJack
7th Gear
I used a test light and they all tested good.
Old Jan 17, 2026 | 12:05 PM
ihc1470's Avatar
ihc1470
Test light is a fair test but it will not tell you the whole story, only that they still have continunity. I prefer using an amp meter and looking for at least a 20 amp draw.
Old Jan 17, 2026 | 02:58 PM
TractorJack
7th Gear
It has a clear stream of fuel coming out. I am now wondering if maybe my starting system is not running at full potential and is not spinning it over fast enough? It might be a mix of glow plugs and starting system. I will look into it some more when it gets warmer.
Old Jan 17, 2026 | 05:01 PM
ihc1470's Avatar
ihc1470
Amp meter for testing.
An amp meter like this makes a inexpensive test meter for glow plug systems. Make one lead long enough to go to a battery and the other to clamp on to the glow plug. Put a couple of vaccuum plugs over the terminals to prevent grounding to the engine.Needle will swing either direction so you do not need to worry about connecting it wrong.
Old Jan 18, 2026 | 05:48 AM
Olds64's Avatar
Olds64
If you also have reason to suspect the starter make sure your battery cables are in good condition. Here's a good thread on a failing starter (with video).
https://www.ford-trucks.com/forums/1...d-starter.html
Old Jan 18, 2026 | 06:37 AM
tjc transport's Avatar
tjc transport
i ain't rite
watch this:
simple easy way to tell if your starter is on it's way out.
i never realized how bad that starter was until one day at a fuel station it refused to turn the engine over after firing up 5 minutes earlier.
Old Jan 18, 2026 | 10:46 AM
Binky7.3's Avatar
Binky7.3
Is your idle solenoid working correctly? Mine doesn't and while it always fires immediately, it can take me 2 or three attempts to get it to run/idle by throttle alone when temperatures are below 35F.
Old Jan 18, 2026 | 10:50 AM
TractorJack
7th Gear
It high idles for a while when cold and then will go back into low so I think it is working.
Old Jan 18, 2026 | 11:22 AM
Mr.Lars's Avatar
Mr.Lars
My ‘91 7.3L is also ‘hard starting’ when temps drop below 40. Keep in mind, these are International Harvester engines(the farm tractor people), we had certain model IH engines that were hard starting when cold, others started no problem till temps were below 0.
Old Jan 18, 2026 | 01:02 PM
TractorJack
7th Gear
Yes, the d282s were notorious hard starters. Are you over on the red power forum? I think I have seen a name like yours over there.
