Anyoe have problems with their fuse panel door? Mine seems to rattle when I'm at a stop, but seems to be getting worse and starting to rattle while in gear and moving. Any ideas how to stop this rattle? I'm going on a trip and don't want to listen to this for 5 hours.
You mean the large one above your knees under the steering column? Why
not go to a local craft store, get a small 2" thick piece of foam rubber
and glue it to the inside of the door, so that when it is closed up
and locked with those 2 plastic quick-screws it will make tight contact
with the support frame under there. That ought to quiet it down.
Just an idea....
btw, I just broke the little center catch-clip on mine the other day and am
waiting for it to start to rattle as yours is starting to do....
