Sponsored by: Auxito
leaking throttle body, lean code
Old Jan 14, 2026 | 09:30 AM
Michael Lizotte's Avatar
Michael Lizotte
How common is a leaking lower gasket on the intake manifold assembly? I sprayed the left side (ds) and it changes the idle, so i think that's were the leak is. Will need to smoke test it to make sure. Truck runs great, but plugs on drivers side have a lot of carbon.
2001, 4.2, 230,000 miles f150xlt
Old Jan 14, 2026 | 11:29 AM
BareBonesXL's Avatar
BareBonesXL
What is a "ds"? And a "lower" throttle body? There's only one throttle body on the front of the intake manifold.
There are known leak spots on the 4.2 intake system.
Old Jan 14, 2026 | 11:56 AM
Michael Lizotte
Drivers Side. Parts show a lower and upper gasket set. Would you recommend replacing the intake with a after market one too?
Old Jan 14, 2026 | 12:09 PM
BareBonesXL
I think that you're talking about the intake manifold assembly. 2001 has the plastic upper and middle manifold, which work just fine, not like the early 4.2 manifolds. The most common leak cause is the isolator bolt grommets hardening. The isolator grommets are what press down on the manifold, causing the gaskets to seal.
Anyway, the fix is to replace the grommets, or just replace the bolts which already have the grommets attached. While you have it apart might as well replace the upper gaskets, and check the IMRC bushings. Unlikely that you need to mess with the lower manifold. Watch out for torque specs, some are in inch-pounds.
https://www.rockauto.com/en/catalog/...tor+bolt,14336
Here's a few videos.
isolator bolt videos
https://www.youtube.com/results?sear...isolator+bolts
Old Jan 14, 2026 | 12:55 PM
Michael Lizotte
Yes that's what I meant manifold. thanks, also heard about replacing the 2 white plastic bushings on the 2 rods in back that fall off.
Michael Lizotte
1997 - 2003 F150
25
Feb 16, 2026 05:32 AM
SD89F150
13
Jun 19, 2024 08:04 PM
SCEPTRE2000
Jan 29, 2011 03:10 PM
