223 question
Old Jan 10, 2026 | 04:35 PM
1957Fridge's Avatar
1957Fridge
223 question
Hello all,
I have this 223 in my '63 F500 that I pulled to reseal & clean up.
Found this bolt & washer covered in RTV, threaded in on the driver's side closest to the rear of the engine. Is there a correct plug available for this?
I tried searching around online for diagrams and such, all I could find was threads saying it's a coolant drain.
Thanks in advance.
Old Jan 10, 2026 | 05:00 PM
fivestarmmd's Avatar
fivestarmmd
Thats where road draft tube attached . Mine has a cup type core hole plug in it
Old Jan 10, 2026 | 05:16 PM
1957Fridge's Avatar
1957Fridge
Ah, I see. Ok, thank you! 😁
Old Jan 10, 2026 | 06:05 PM
spurredon's Avatar
spurredon
Also known as the driveway oiler.
Old Jan 10, 2026 | 06:10 PM
1957Fridge's Avatar
1957Fridge
That name I had heard thrown around.
I'll have to pressure test the cooling system on the stand. I had coolant on the bottom of the transmission & on the throwout bearing, so it's coming from somewhere.
Old Jan 10, 2026 | 10:58 PM
rusty valley's Avatar
rusty valley
That road draft tube was there for a reason. All motors prior to the invention of the PCV ....positive crankcase ventilation valve, used this system for the engine to breath. Air enters the oil fill cap, due to vacuum from the road draft tube created by driving down the road. to simply just close it off, you will make crankcase pressure that needs to go somewhere. For example, my 1952 ****** m38 army jeep. ****** figured there is about 3 lbs of pressure in the crankcase from piston movement. They use this pressure to pressurize components for deep water crossings. Close a valve on the dash, and the crankcase pressure is routed to the transmission, transfercase, distributor, gas tank, so that in theory, air is going out instead of water going in. My ****** carrying some vets in the parade. The guy needing a haircut is me
Class dismissed.
Old Jan 11, 2026 | 08:44 AM
tripleframe's Avatar
tripleframe
Your 223 probably had the same system used on the 262.
Alblooki
Dec 12, 2024 05:23 AM
Bassmaster96
Aug 29, 2024 04:11 PM
JLBA210
15
Aug 27, 2024 12:54 PM
Gary366
Apr 28, 2024 09:55 AM
mattmattn
Jan 2, 2018 01:46 PM
