Air intake temp sensor relocation
I have a 1993 F150 with the 4.9L. I saw on a video online a recommendation to relocate the air intake temp sensor so that it's on the box with the air filter, just after the filter, and away from the heat of the engine. Is this something I should look into? Asking because I already had the sensor out since I have the head off the engine at the moment.
On the intake is the most accurate temp for fuel mixture calculations. It’s reading the air just before it enters the combustion chamber. If you move it somewhere else, you need to be able to remap your fueling based off that.
I kinda wonder if it's a J type or K type thermocouple in this thing. We use one type with some of our test equipment at work, but the circuit board reflow oven uses the other type. Only reason I know that is I was asked to help diagnose an issue with the oven lately. We only use it for prototyping runs, so it doesn't get near the use it did before our company was acquired by big blue.
Whichever type it is, I can't just use the Fluke 179 at the office to read it directly, so it's not a k-type. In any case, at room temp it's reading around 33k, and it goes down when I breathe on it, like any other ntc thermistor. So the thing is good in my book. It was caked in grime when I first pulled it out. You wouldn't have known that the thermistor in the middle was red instead of black, and you couldn't tell the shape of it either. Most of a can of MAF cleaner got it cleaned up nicely though.
The airbox location is specific to a MAF computer & intake for Speed Density.
The MAF computer needs the closest air temp to the MAF sensor to do its calculations.
John7894
Dec 30, 2017 08:52 PM
