E85
Old Jan 3, 2026 | 01:22 PM
whitey68's Avatar
whitey68
E85
I've had my truck for 4 years but I forgot how lousy my mileage is on E85 an filled up with it last week.
My brother-in law has a 15 5.0 that he runs E50 in and says he gets 19 or better with but i just haven't drank the cool aide on that yet.
normally with my 16 5.0 I get 14.8 to 15.7 according to the lom , thats on shell 87.
what are you all getting out of your trucks?
Old Jan 3, 2026 | 06:20 PM
SpencerPJ's Avatar
SpencerPJ
Most will say 87 is the sweet spot, some do better with a tune on 85. The 85 lower price typically does not offset mpg. Same goes with better octane, 89,91 etc. Higher price doesn't offset mpg, butttt, better octane can give better performance, and that's priceless
Old Jan 3, 2026 | 09:03 PM
whitey68's Avatar
whitey68
truck has more giddy up with e85 also with mobil 87 both get less mpg, I don't understand it because my driving habits are pretty consistent.
now when I tow the 30ft camper 8mpg maybe 10 on a smooth stretch, plus I tow in 5th I keep it from shifting into 6th.
Old Jan 4, 2026 | 07:04 AM
SpencerPJ's Avatar
SpencerPJ
fyi. my 3.5 gets similar mpg running 89 pulling slightly smaller travel trailer,
Old Jan 5, 2026 | 06:12 AM
2017coyote's Avatar
2017coyote
My 5.0 gets 19.4 most of the time on average. Regular 87 from Krogers.
Old Jan 5, 2026 | 11:29 AM
JKBrad's Avatar
JKBrad
E85 is not 85 octane. E stands for ethanol, 85 indicates it's percentage of ethanol. So E85 is an 85% ethanol/15% gasoline engine fuel.
Gasoline comes in several octane ratings, commonly 85, 87, 89, 91, 93. 85 octane is usually only seen in ares where the elevation is over 5000'. Octane is a rating to indicate how knock resistant the fuel is. The high the octane, the more knock resistant it is. Higher octane fuel is required for high compression engines, and/ or engines with high performance tunes. Gasoline with those octane ratings will have no more then 15% ethanol, usually 10%.
E85 should only be used in vehicles with engines that are designed for dual fuel use. Those will always have a badge on them somewhere that say Flex Fuel. Those engines are equipped with a fuel system that can adapt to varying levels of ethanol. An engine than is running E85 fuel will typically get 20-25% less fuel economy than when it's ran on gasoline.
Old Jan 5, 2026 | 03:17 PM
whitey68's Avatar
whitey68
Anyone run e50?
Old Jan 5, 2026 | 04:45 PM
2017coyote's Avatar
2017coyote
E85 has around a 105 octane rating.
Old Jan 5, 2026 | 06:05 PM
JKBrad's Avatar
JKBrad
Correct. I think many people assume it’s 85 octane gasoline, and use it because it’s somewhat less expensive, even if their vehicle isn’t Flex Fuel rated.
Old Jan 6, 2026 | 06:45 AM
SpencerPJ's Avatar
SpencerPJ
Great thread, thanks for the education
Budlight67
5.0L Coyote
13
May 2, 2024 12:19 PM
lwk362393
2015 - 2020 F150
39
Nov 3, 2021 01:23 PM
ndoutdoors
6.2L V8
Apr 2, 2016 08:08 PM
tilelayher
EcoBoost (all engine sizes)
Dec 13, 2013 09:02 AM
Gary Atsma
2009 - 2014 F150
15
Nov 12, 2013 01:06 PM
