Rapid supplemental heat
Old Jan 1, 2026 | 11:56 AM
Garbageman 134's Avatar
Garbageman 134
Is there a way for a Ford mobile technician to see if the rapid supplemental heating system is activating when the truck is started cold? I have the Dual alternator dual battery option
Old Jan 1, 2026 | 12:32 PM
Joe T's Avatar
Joe T
Find a way to pull up your original window sticker. I think carfax or the dealer can.
I assume this is the question, have it or not.
Old Jan 1, 2026 | 01:27 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Dual alts is part of the supplemental heater package.
Has to be cold enough before the supplemental heat activates, I don't recall what the temp threshold is.
But, if that condition is met, then a tech with a IDS scan tool should be able to see it.
Old Jan 1, 2026 | 02:01 PM
Flatland1's Avatar
Flatland1
Turn your temp selector to high...........it won't come on if it isn't
Old Jan 1, 2026 | 03:57 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Mine comes on without temp set to high or max or whatever, so long as it is very cold out.
Old Jan 2, 2026 | 12:58 AM
Garbageman 134
14F and temp set to HI.
Old Jan 2, 2026 | 05:06 AM
Joe T's Avatar
Joe T
It isnt very strong. Just luke warm, enough to cut the cold bone chill.
Glad its in the 70s here today 😅
Old Jan 2, 2026 | 06:49 AM
BDWSD22's Avatar
BDWSD22
Max Defrost on a cold morning will trigger it on. If the diesel engine is cold started the coolant will be cold for some time without driving.
Old Jan 4, 2026 | 02:36 PM
jimzpsd's Avatar
jimzpsd
My '17 has this feature, this morning it was -18*F, I started the truck and set the controls to activate the supplemental heater, with in three minutes I could smell it, almost like burning dust. Since day one with this truck this has always been my indicator telling me its on. Works good too.
Old Jan 5, 2026 | 06:08 AM
99powerstrokedF250's Avatar
99powerstrokedF250
This right here is what it says in my manual. And it works...for the most part. It's probably only putting out 80° or so tops, which with a decent fan speed doesn't even really feel warm...just warmer than outside.
ZF6PSD
18
Apr 6, 2025 05:33 AM
bajadudes
Apr 19, 2024 07:16 PM
cnvF250
6.7L Power Stroke Diesel
45
Jun 20, 2011 10:00 PM
jack_pine
Apr 19, 2011 11:20 AM
HH60FE
15
Nov 3, 2008 04:52 PM
