It’s been a while
Old Dec 31, 2025 | 07:39 PM
wmjoe1953's Avatar
wmjoe1953
It’s been a while
A few familiar usernames. Quite a few new ones. It’s a long time since I’ve been here. The current stable includes a 1955 Ford F-350 1 Ton Express (which has been posted on before). My dad bought it from the original owners when I was not even a year old. I also have recently acquired a 1955 F-800 dump truck. It seems that I just can’t stay away from the Big Jobs. I also have a 2000 F-250 Super Duty, but it’s currently completely disassembled and being fitted with a 460 based 521 Stroker (undecided if I’m going to run Kaase P51 heads or Kaase Boss Nine heads), and a 5 speed manual transmission.
Old Dec 31, 2025 | 08:01 PM
52 Merc's Avatar
52 Merc
Welcome back, Joe. Good to see you here again. I must admit, you've peaked my interest with your Kaase 521 in a 2000 F250. What's your plans for such a hipo engine in an old work truck? Are you custom fitting it, or is there an install kit for such a monster?
Old Dec 31, 2025 | 08:09 PM
wmjoe1953's Avatar
wmjoe1953
It’s been a while. So, no kits. This one is all fabrication required. I was running a 302 based 331 in it, and it was definitely fun at right at 500 horses, but I needed bigger. The 460 block tends to risk pulling the sides out at the motor mounts with too much torque, so I’m boxing in the front frame and will be running motor plates. Holley Terminator X EFI, MSD crank trigger and coil near plug ignition, big roller cam, etc. I’m shooting for around 800 horses N/A. I’m also working on the correct restoration of the 55 F-350. I have the engine almost done, and I tracked down a donor 53 Express that’s parted out with a decent bed. It may have enough parts to help spruce up the Big Job as well.
Old Jan 2, 2026 | 04:36 PM
Moe Craig's Avatar
Moe Craig
That Avatar looks familiar... But I've been scarce on here too. Nice to see ya again!
Old Jan 2, 2026 | 05:14 PM
1952henry's Avatar
1952henry
Welcome back!
Old Jan 2, 2026 | 08:17 PM
mOROTBREATH's Avatar
mOROTBREATH
I remember when I first came around here, seeing your Avatar picture was the COOLEST avatar pic ever by a long shot. Always remembered you because of it.
I'm very glad to not only see you back, but apparently you're very active in enjoying ole trucks! You should post some pics of the F800
Old Jan 3, 2026 | 09:24 AM
abe's Avatar
abe
Hey Joe, welcome back. You always had interesting and informative posts.
Yes show us pics of your F350 for new members and to refresh our older guys memories.
GetMore
Jan 28, 2024 05:57 PM
Stephen Sage
Oct 15, 2022 08:05 PM
Strokin-A-2010
Apr 5, 2020 06:26 PM
rock2610d
Feb 26, 2017 08:16 AM
chaser460
May 5, 2013 10:00 PM
