does anyone know the size of the o-ring for the line that runs from the bottom of the Degas bottle to the front of the lower engine? I think the o-ring that seals the bottom of the Degas bottle is bad.
SPE has a kit for $140 "the billet aluminum quick connect will not warp, deform, etc & therefore the o-ring stays contained."
Not sure if the cost is acceptable, but I've read a new o ring doesn't always fix it and some that are fixed don't last long. My hasn't leaked yet but I'm getting close to time for a coolant flush/change and will install the SPE kit then.
I found that kit and will probably pull the trigger on it soon, thx for posting it though
