Help with IP problems. No fuel out of return port of IP wvo 7.3 Idi
Old Dec 27, 2025 | 10:15 PM
Akehurst's Avatar
Akehurst
4wd High
Stuck with no fuel reaching injectors.
Thing I have tried:
  • bleeding air from fuel filter bleed port
  • hand pumping fuel directly to IP intake
  • cracking injectors
  • testing fss, as well as removing IP top to check fss function, bowl is full of fuel
  • cranking engine for many days, with fuel soaked rag in air intake
  • Inspected IP cam rotation
  • pressurized system from the shraerder valve on the fuel filter
  • Notice there is no fuel coming out of return port on IP while cranking.
Not sure where to turn next.
Old Mar 4, 2026 | 09:55 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
What did you find out, the IP was shot?
Old Mar 4, 2026 | 04:45 PM
Akehurst's Avatar
Akehurst
4wd High
Hey,
the drive shaft in the IP sheared, ☹️
Akehurst
Jan 2, 2026 07:51 AM
Akehurst
Dec 29, 2025 07:39 AM
Evancortis
Feb 23, 2025 04:53 PM
cableguy1169
May 30, 2022 01:15 PM
1978FrankenFord
18
Mar 7, 2018 07:04 AM
