New (Again!) Owner
Old Dec 22, 2025 | 06:50 PM
mml373's Avatar
mml373
New (Again!) Owner
Well, got my new to me 1990 F-150 home. 302, 2 wheel drive, AOD, with 3.55 gears. Brown with tan in the middle, tan interior. It is going to need A LOT of work. Body has some rust spots that will need Bondo, I guess. New paint and body work when I finally get everything else done...perhaps to include a new truck-performance-built AOD and a 302 rebuild to focus on towing performance.
Dies when rear tank is tried.
Rough idle, surges.
Voltage gauge fluctuates as it idles...idle seems slow.
Guessing cat is clogged.
Let the games begin...Cha-ching! But not as expensive as a new truck would be. This one is for my youngest son, who turns 16 in 10 years. We have time. :-)
Old Dec 22, 2025 | 07:59 PM
Staticbuster's Avatar
Staticbuster
Cool truck, sounds about like my first one, a '93 2wd long bed with 300-6 and AOD. A '90 is a bricknose, not a bullnose, so you might get more help posting in the 87-96 section than in here, but still enjoy reading about it.
Old Dec 22, 2025 | 08:02 PM
FuzzFace2's Avatar
FuzzFace2
Welcome MML373 to FTE.
I hope the year of the truck you posted was a type-o (1990) as you are in the 80 to 96 truck area.
The 87 - 92? is just above this area.
I also say this as I did not think 80 had a 302 / AOD, well maybe a 302 but AOD?
Either way got pictures of the truck?
Dave ----
Old Dec 23, 2025 | 07:22 AM
Franklin2's Avatar
Franklin2
AOD came out in these trucks in 1981.
Old Dec 23, 2025 | 07:50 AM
FuzzFace2's Avatar
FuzzFace2
So if he miss typed 1990 and not 1980 like I thought it still would not have the AOD transmission unless someone did a swap and we know that never happens
Dave ----
Old Dec 23, 2025 | 02:01 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by mml373
Body has some rust spots that will need Bondo, I guess...perhaps to include a new truck-performance-built AOD and a 302 rebuild to focus on towing performance.
Rough idle, surges.
How are you going to Bondo rust? That sounds like a recipe for increasing the rate that it rusts. Increasing the strength of the AOD would never be a bad idea.
Only when using the rear tank?
Check for (KOEO) fault codes
Check voltage at the battery with a meter
That would be at the bottom of the list if it even made the list of possible causes
Dave ----
Why wouldn’t it?
Old Dec 23, 2025 | 03:07 PM
mml373's Avatar
mml373
Aww, rats! Clicked the wrong forum and posted! Can mods move this thread?
I love the bullnose trucks, too! Will be cutting wheel well areas out and putting in new panel sections...and Bondo'ing elsewhere where it makes sense.
Old Dec 23, 2025 | 04:34 PM
FuzzFace2's Avatar
FuzzFace2
Why wouldn’t it?
If you look at DaveF post he said the AOD came out in 1981 and you are listing it from 85>
So if the OP had a 1980 truck it would not have a AOD unless someone swapped it in.
But look below it is a 1990 and he posted in the wrong area.
It happens to the best of us.
I am sure when a mod sees this he will move it.
Good luck
Dave ----
Old Dec 23, 2025 | 05:21 PM
My4Fordtrucks
True…. If you think the year was mistyped. Stalling when switching to the rear tank make more sense to me as a ‘90 model than an ‘80.
Old Dec 24, 2025 | 06:28 AM
FuzzFace2's Avatar
FuzzFace2
The 80's 5.0 fuel systems confuse me, easy to do, but I would think the rear fuel pump, low or high PSI, would be bad and / or switching valve not working.
Being a 90 model I am guessing it has high PSI in tank pumps so the rear pump or valve is bad would be my guess.
Does the fuel gauge change when you flip the switch may be a clue?
Dave ----
Old Dec 24, 2025 | 07:28 AM
My4Fordtrucks
1990 has high pressure pumps in each tank. Not necessarily since the sending unit is a different circuit from the pump.
thebigyetti
Aug 4, 2011 09:50 AM
Will Kilpatrick
Jan 29, 2007 04:09 PM
69 and 85
Iowa Chapter
24
Apr 20, 2005 11:27 AM
