Sponsored by: Real Truck
4wd hub question
Old Dec 18, 2002 | 08:21 AM
Big Red F250 SD's Avatar
Big Red F250 SD
4wd hub question
Why do the hubs have an "automatic" and a "locked" position? What's the difference? I always thought that if the hubs were automatic, they would automatically lock in when put in 4wd. Saturday, I was in some mud and put it in 4 low with the hubs in the "automatic" position and not much happened. When I got out and locked them, the front engaged. Also, my truck pulled hard to the right for a little while after locking and engaging 4 low. Thank you for your input.
p.s. I have a 2000 F-250 5.4L
Old Dec 18, 2002 | 08:50 AM
Monsta's Avatar
Monsta
Sit. Stay.
4wd hub question
See the FAQ for your answers about the lock feature.
You still need some forward movement to ensure a positive lock on the hubs.
As far as the pulling, sounds likes common thing. Lotsa torque, reduced gearing...the pinion was trying to climb up the ring and it pulled the whole truck a bit.
Old Dec 18, 2002 | 10:48 AM
spartamouse1's Avatar
spartamouse1
4wd hub question
in the "auto" position the hubs will lock when you turn the ****. you should be stopped when you do this.
in the lock position you can be driving down the road and turn the **** and shift on the fly. so if the side streets are bad and the main roads are clear, you can be driving down a main road, trun on a side street and go into 4x4 without stopping.
Old Dec 18, 2002 | 11:11 AM
Waxy's Avatar
Waxy
4wd hub question
The OPPOSITE is true. In fact, you need to be moving, either forward or backward in order for the hubs to engage automatically.
>without stopping.
This can be done with the hubs in auto as well. Just remember that if the hubs are unlocked and in auto it's going to take approximately 10-20' for the hubs to lock AFTER you turn the switch. If the hubs are already locked manually, the shift to 4X4 is almost instantaneous.
THERE IS NO NEED TO STOP TO SHIFT TO UNLESS SHIFTING INTO 4X4 LOW!
Waxy
Old Dec 18, 2002 | 06:35 PM
FortyFords's Avatar
FortyFords
4wd hub question
OOOOOOOOOOOOOOHHHHHHHHHHHHH Joys of ESOF!!!!!!!!!!!!
Lock the dang things ! FORGET ABOUT IT !!!!!!!
oops! got carried away!
:-X12 :-X12 :-X12
Rich
The guys have told eveything about how it works !
Make sure you speak to the Esof gods before turning that switch!
Oh Big Red 250!!!!!!
WELCOME TO FTE !!!!!!! Since none of those other guys did!!!!!!
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Dec 19, 2002 | 09:45 AM
fsnco1's Avatar
fsnco1
4wd hub question
WAXY is right, when in auto, the hubs will engage when shifted, sometimes if your hubs are hard to turn or dirty, they won't go all the way to the lock position, but if you're moving, it will help to move them into lock.
Definetely only go into 4Low when stopped, I made the foolish mistake of doing it while moving (actually trying to disengage) Not a smart move, it will make ugly moises and not disengage. thank the ESOF gods nothing went wrong!!!
Old Dec 19, 2002 | 07:32 PM
adolphbell's Avatar
adolphbell
4wd hub question
During our last snow here in S. W. Missouri (8") I was unable to move up my drive on packed snow in 2wd. I stepped on the brake shifted the **** into 4x4 and the front hubs locked as soon as I pressed the accelerator. I thought with the electronic shift I would have to move several feet, but at least with a new truck I have not had to do that (tried it again the next morning, and had the same instant response). So, while supposedly the truck must move a few feet to lock the hubs, I have not found that to be the case.
2002 4x4 F250 V10 CC Lariat
Old Dec 19, 2002 | 11:26 PM
Beermaker's Avatar
Beermaker
4wd hub question
